Updates the node information or performs shutdown/reboot actions on a node
storage failover modify -
system node modify -
system node reboot -
system node power off -
system node power on -
system service-processor network modify -
system service-processor reboot-sp -
system service-processor image modify
PATCH /cluster/nodes/{uuid}
Introduced In: 9.6
Updates the node information or performs shutdown/reboot actions on a node.
Related ONTAP commands
cluster ha modify -
uuid |
string |
path |
True |
action |
string |
query |
False |
The shutdown action shuts the node down and transfers storage control to its HA group if storage failover is enabled. The reboot action reboots the node and transfers storage control to its HA group if storage failover is enabled. The giveback action transfers storage control back to the owner from its HA group. The "power_off" action shuts the node down with the assistance of the service processor. The "power_on" action restores power to the node with the assistance of the service processor.
shutdown_reboot_reason |
string |
query |
False |
Indicates the reason for the reboot or shutdown. This only applies when an action of reboot or shutdown is provided. |
allow_data_outage |
boolean |
query |
False |
This only applies when an action of reboot or shutdown is provided. It allows storage failover to be bypassed along with any failures related to mainintaing quorum in the cluster.
service_processor.firmware_image |
string |
query |
False |
Service processor image to boot with after a reboot.
service_processor.action |
string |
query |
False |
Action used to reboot the service processor (SP).
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
ha |
is_spares_low |
boolean |
Specifies whether or not the node is in spares low condition. |
location |
string |
management_interfaces |
array[management_interfaces] |
membership |
string |
Possible values:
metrocluster |
Metrocluster |
model |
string |
name |
string |
nvram |
owner |
string |
Owner of the node. |
serial_number |
string |
service_processor |
state |
string |
State of the node:
storage_configuration |
string |
The storage configuration in the system. Possible values:
system_id |
string |
system_machine_type |
string |
OEM system machine type. |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
vendor_serial_number |
string |
OEM vendor serial number. |
vm |
Example request
"cluster_interfaces": [
"name": "lif1",
"controller": {
"board": "System Board XXVIII",
"cpu": {
"count": 20,
"firmware_release": "string",
"processor": "string"
"failed_fan": {
"count": 1,
"message": {
"code": "111411207",
"message": "There are no failed fans."
"failed_power_supply": {
"count": 1,
"message": {
"code": "111411208",
"message": "There are no failed power supplies."
"flash_cache": [
"capacity": 1024000000000,
"device_id": 0,
"firmware_file": "X9170_O000Z6300NVM",
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": "string",
"state": "string",
"type": "string"
"memory_size": 1024000000,
"over_temperature": "string"
"date": "2019-04-17T11:49:26-04:00",
"ha": {
"giveback": {
"failure": {
"code": 852126,
"message": "Failed to initiate giveback. Run the \"storage failover show-giveback\" command for more information."
"state": "failed"
"partners": [
"name": "node1",
"ports": [
"number": 0,
"state": "active"
"takeover": {
"failure": {
"code": 852130,
"message": "Failed to initiate takeover. Run the \"storage failover show-takeover\" command for more information."
"state": "failed"
"location": "rack 2 row 5",
"management_interfaces": [
"name": "lif1",
"membership": "string",
"metrocluster": {
"ports": [
"name": "e1b"
"type": "string"
"model": "FAS3070",
"name": "node-01",
"nvram": {
"battery_state": "string",
"id": 0
"owner": "Example Corp",
"serial_number": "4048820-60-9",
"service_processor": {
"backup": {
"state": "string",
"version": "11.6"
"firmware_version": "string",
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"ipv6_interface": {
"address": "fd20:8b1e:b255:5011:10:141:4:97",
"gateway": "fd20:8b1e:b255:5011:10::1",
"netmask": 64
"last_update_state": "string",
"link_status": "string",
"mac_address": "string",
"primary": {
"state": "string",
"version": "11.6"
"ssh_info": {
"allowed_addresses": [
"10.10.10.7/24"
"state": "string",
"type": "string"
"state": "string",
"storage_configuration": "string",
"system_id": "0537035403",
"system_machine_type": "7Y56-CTOWW1",
"uptime": 300536,
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"vendor_serial_number": "791603000068",
"vm": {
"provider_type": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
852046 |
HA partner node |
852115 |
The reboot/shutdown is prevented because LIFs cannot be moved away from the node |
3604514 |
A reboot or shutdown request is already in progress. |
3604515 |
Reboot or shutdown of all nodes results in data service failure and client disruption for the entire cluster. Use "allow-data-outage=true" to bypass this check. |
9240606 |
The reboot/shutdown is prevented due to quorum warnings. |
href |
string |
_links
node_setup_ip
The IP configuration for cluster setup.
address |
string |
IPv4 or IPv6 address |
cluster_interface
The cluster network IP address of the node to be added.
ip
IP information
cluster_interfaces
Network interface
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
cpu
CPU information.
count |
integer |
Number of CPUs on the node. |
firmware_release |
string |
Firmware release number. Defined by the CPU manufacturer. |
processor |
string |
CPU type on the node. |
message
code |
string |
Error code describing the current condition of chassis fans. |
message |
string |
Message describing the current condition of chassis fans. It is only of use when |
failed_fan
count |
integer |
Specifies a count of the number of chassis fans that are not operating within the recommended RPM range. |
message |
message
code |
string |
Error code describing the current condition of power supply. |
message |
string |
Message describing the state of any power supplies that are currently degraded. It is only of use when |
failed_power_supply
count |
integer |
Number of failed power supply units. |
message |
flash_cache
capacity |
integer |
Size in bytes |
device_id |
integer |
firmware_file |
string |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
string |
state |
string |
type |
string |
controller
board |
string |
Type of the system board. This is defined by vendor. |
cpu |
CPU information. |
failed_fan |
failed_power_supply |
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
List of FRUs on the node. Only returned when requested by name. |
memory_size |
integer |
Memory available on the node, in bytes. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
external_cache
Cache used for buffer management.
failure
Indicates the failure code and message.
code |
integer |
Message code |
message |
string |
Detailed message based on the state. |
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure |
Indicates the failure code and message. |
state |
string |
partners
name |
string |
uuid |
string |
ports
number |
integer |
HA port number |
state |
string |
HA port state:
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure |
state |
string |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
giveback |
Represents the state of the node that is giving storage back to its HA partner. |
partners |
array[partners] |
Nodes in this node's High Availability (HA) group. |
ports |
array[ports] |
takeover |
This represents the state of the node that is taking over storage from its HA partner. |
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the managment interfaces of other nodes.
Network interface
ip |
IP information |
name |
string |
uuid |
string |
metric
CPU performance for the nodes.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
processor_utilization |
integer |
Average CPU Utilization for the node |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
timestamp |
string |
The timestamp of the performance data. |
uuid |
string |
ports
name |
string |
metrocluster
Metrocluster
custom_vlan_capable |
boolean |
Indicates whether the MetroCluster over IP platform supports custom VLAN IDs. |
ports |
array[ports] |
MetroCluster over IP ports. |
type |
string |
The Metrocluster configuration type |
nvram
battery_state |
string |
Specifies status of the NVRAM battery. Possible values:
id |
integer |
Vendor specific NVRAM ID of the node. |
backup
Provides the properties of the service processor backup partition.
is_current |
boolean |
Indicates whether the service processor is currently booted from the backup partition. |
state |
string |
Status of the backup partition. |
version |
string |
Firmware version of the backup partition. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ipv6_interface
address |
string |
IPv6 address |
gateway |
string |
The IPv6 address of the default router. |
netmask |
integer |
The IPv6 netmask/prefix length. The default value is 64 with a valid range of 1 to 127. |
primary
Provides the properties of the service processor primary partition.
is_current |
boolean |
Indicates whether the service processor is currently booted from the primary partition. |
state |
string |
Status of the primary partition. |
version |
string |
Firmware version of the primary partition. |
ssh_info
Service processor SSH allowed IP address configuration applied across the cluster.
allowed_addresses |
array[string] |
Allowed IP addresses |
service_processor
autoupdate_enabled |
boolean |
Indicates whether the service processor can be automatically updated from ONTAP.
backup |
Provides the properties of the service processor backup partition. |
dhcp_enabled |
boolean |
Set to "true" to use DHCP to configure an IPv4 interface. Do not provide values for address, netmask and gateway when set to "true". |
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
Object to setup an interface along with its default router. |
ipv6_interface |
is_ip_configured |
boolean |
Indicates whether the service processor network is configured. |
last_update_state |
string |
Provides the "update status" of the last service processor update. |
link_status |
string |
mac_address |
string |
primary |
Provides the properties of the service processor primary partition. |
ssh_info |
Service processor SSH allowed IP address configuration applied across the cluster. |
state |
string |
type |
string |
statistics
Raw CPU performance for the nodes.
processor_utilization_base |
integer |
Base counter for CPU Utilization. |
processor_utilization_raw |
integer |
Raw CPU Utilization for the node. This should be divided by the processor_utilization_base to calculate the percentage CPU utilization for the node. |
status |
string |
timestamp |
string |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
vm
provider_type |
string |
Cloud provider where the VM is hosted. |
node
Complete node information
controller |
date |
string |
ha |
is_spares_low |
boolean |
location |
string |
membership |
string |
Possible values:
metrocluster |
Metrocluster |
model |
string |
name |
string |
nvram |
owner |
string |
serial_number |
string |
service_processor |
state |
string |
State of the node:
string |
system_id |
string |
string |
uptime |
integer |
uuid |
string |
string |
vm |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
