Update an NTP server configuration after validation
Updates the configuration of an NTP server used by the ONTAP cluster. This is useful for maintaining accurate time synchronization across the cluster.
HTTP method and endpoint
PATCH /cluster/ntp/servers/{server}
Introduced in
ONTAP 9.7
Usage notes
Updates the configuration of an NTP server used by the ONTAP cluster after validation. Patchable fields are:
version -
key.id -
authentication_enabled
If authentication_enabled is modified to false, the associated NTP key is removed from the server instance.
If authentication_enabled is modified to true, you must provide an NTP key ID in the PATCH body.
Related ONTAP commands
cluster time-service ntp server modify
Learn more
server |
string |
path |
True |
Server address or host name |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
authentication_enabled |
boolean |
Set NTP symmetric authentication on (true) or off (false). |
key |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
Example request
"authentication_enabled": 1,
"key": {
"id": 10
"version": "auto"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097163 |
NTP server address was invalid. |
2097164 |
2097165 |
Could not resolve NTP server hostname. |
2097166 |
NTP server address query returned no valid IP addresses. |
2097167 |
Failed to connect to NTP server. |
2097169 |
NTP server provided was not synchronized. |
2097174 |
NTP server provided had too high of root distance. |
2097177 |
NTP server provided had an invalid stratum. |
2097181 |
2097182 |
2097183 |
NTP symmetric key authentication cannot be used for a node not in a cluster. |
2097185 |
NTP key authentication failed for the provided key. |
2097188 |
An invalid key identifier was provided. Identifiers must be in the range from 1 to 65535. |
2097193 |
An unknown key was provided. |
2097194 |
The field "authentication_enabled" cannot be false when the field NTP key is given. |
href |
string |
_links
ntp_key_reference
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
ntp_server
boolean |
key |
version |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
