REST API reference
Update an NTP server configuration after validation
PATCH /cluster/ntp/servers/{server}
Introduced In: 9.7
Updates the configuration of an NTP server used by the ONTAP cluster after validation. Patchable fields are:
  • version
  • key.id
  • authentication_enabled
If authentication_enabled is modified to false, the associated NTP key is removed from the server instance. If authentication_enabled is modified to true, you must provide an NTP key ID in the PATCH body.
  • cluster time-service ntp server modify
server
string
path
True
Server address or host name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
boolean
Set NTP symmetric authentication on (true) or off (false).
key
ntp_key_reference
version
string
NTP protocol version for server. Valid versions are 3, 4, or auto.
Example request
  "authentication_enabled": 1,
  "key": {
    "id": 10
  "version": "auto"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
2097163
NTP server address was invalid.
2097164
2097165
Could not resolve NTP server hostname.
2097166
NTP server address query returned no valid IP addresses.
2097167
Failed to connect to NTP server.
2097169
NTP server provided was not synchronized.
2097174
NTP server provided had too high of root distance.
2097177
NTP server provided had an invalid stratum.
2097181
2097182
2097183
NTP symmetric key authentication cannot be used for a node not in a cluster.
2097185
NTP key authentication failed for the provided key.
2097188
An invalid key identifier was provided. Identifiers must be in the range from 1 to 65535.
2097193
An unknown key was provided.
2097194
The field "authentication_enabled" cannot be false when the field NTP key is given.
string
ntp_key_reference
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server.
ntp_server
boolean
key
ntp_key_reference
version
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
