REST API reference
Update a schedule
Updates a schedule to change its configuration settings, adjusting how and when certain tasks are executed. Use this endpoint when you need to refine operational timing without altering the core schedule type.
HTTP method and endpoint
PATCH /cluster/schedules/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Note that you cannot modify a cron field of an interval schedule, or the interval field of a cron schedule.
uuid
string
path
True
Schedule UUID
Request Body
Name Type Description
cron
cron
Details for schedules of type cron.
interval
string
An ISO-8601 duration formatted string.
scope
string
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
type
string
Schedule type
uuid
string
Job schedule UUID
Example request
  "cron": {
    "days": [
      "integer"
    "hours": [
      "integer"
    "minutes": [
      "integer"
    "months": [
      "integer"
    "weekdays": [
      "integer"
  "interval": "P1DT2H3M4S",
  "scope": "string",
  "type": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
458788
The schedule specified is not a valid schedule.
459760
459761
Schedule cannot be modified on this cluster because it is replicated from the remote cluster.
460783
As this is a MetroCluster configuration and the local cluster is waiting for switchback, changes to non-system schedules are not allowed.
string
cluster
The cluster that owns the schedule. Defaults to the local cluster.
name
string
Cluster name
uuid
string
Cluster UUID
cron
days
array[integer]
The days of the month the schedule runs. Leave empty for all.
hours
array[integer]
The hours of the day the schedule runs. Leave empty for all.
minutes
array[integer]
The minutes the schedule runs. Required on POST for a cron schedule.
months
array[integer]
The months of the year the schedule runs. Leave empty for all.
weekdays
array[integer]
The weekdays the schedule runs. Leave empty for all.
svm
name
string
The name of the SVM.
uuid
string
schedule
Complete schedule information
cron
cron
interval
string
scope
string
type
string
Schedule type
uuid
string
Job schedule UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
