Update a schedule
PATCH /cluster/schedules/{uuid}
Introduced In: 9.6
Updates a schedule. Note that you cannot modify a cron field of an interval schedule, or the interval field of a cron schedule.
uuid  |
string  |
path  |
True  |
Schedule UUID  |
Request Body
| Name | Type | Description |
cron  |
Details for schedules of type cron.  |
interval  |
string  |
An ISO-8601 duration formatted string.  |
scope  |
string  |
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.  |
type  |
string  |
Schedule type  |
uuid  |
string  |
Job schedule UUID  |
Example request
  "cron": {
    "days": [
      "integer"
    "hours": [
      "integer"
    "minutes": [
      "integer"
    "months": [
      "integer"
    "weekdays": [
      "integer"
  "interval": "P1DT2H3M4S",
  "scope": "string",
  "type": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
458788  |
The schedule specified is not a valid schedule.  |
459760  |
459761  |
Schedule cannot be modified on this cluster because it is replicated from the remote cluster.  |
460783  |
As this is a MetroCluster configuration and the local cluster is waiting for switchback, changes to non-system schedules are not allowed.  |
461785  |
A cron schedule cannot have an interval field.  |
461786  |
An interval schedule cannot have a cron field.  |
href  |
string  |
_links
cluster
The cluster that owns the schedule. Defaults to the local cluster.
name  |
string  |
Cluster name  |
uuid  |
string  |
Cluster UUID  |
cron
days  |
array[integer]  |
The days of the month the schedule runs. Leave empty for all.  |
hours  |
array[integer]  |
The hours of the day the schedule runs. Leave empty for all.  |
minutes  |
array[integer]  |
The minutes the schedule runs. Required on POST for a cron schedule.  |
months  |
array[integer]  |
The months of the year the schedule runs. Leave empty for all.  |
weekdays  |
array[integer]  |
The weekdays the schedule runs. Leave empty for all.  |
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
schedule
Complete schedule information
cron  |
interval  |
string  |
scope  |
string  |
type  |
string  |
Schedule type  |
uuid  |
string  |
Job schedule UUID  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
