REST API reference
Re-order a CIFS home directory search path
Reorders a CIFS home directory search path to modify the sequence in which directories are searched, optimizing access and organization.
HTTP method and endpoint
PATCH /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Introduced in
ONTAP 9.6
  • cifs server home-directory search-path reorder
index
integer
path
True
Home directory search path index
new_index
integer
query
False
New position for the home directory search path
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655463
Failed to reorder the search-path because the new-index is invalid. It cannot be '0' and it cannot go beyond the current entries
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
