Re-order a CIFS home directory search path
PATCH /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Introduced In: 9.6
Reorders a CIFS home directory search path.
Related ONTAP commands
cifs server home-directory search-path reorder
index |
integer |
path |
True |
Home directory search path index |
new_index |
integer |
query |
False |
New position for the home directory search path |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655463 |
Failed to reorder the search-path because the new-index is invalid. It cannot be '0' and it cannot go beyond the current entries |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
