Update export policy properties
Updates the properties of an export policy to modify its name or replace its rules and manage access effectively for your network file systems.
HTTP method and endpoint
PATCH /protocols/nfs/export-policies/{id}
Introduced in
ONTAP 9.6
Usage notes
Updates the properties of an export policy to change an export policy name or replace all export policy rules.
Related ONTAP commands
vserver export-policy rename -
vserver export-policy rule delete -
vserver export-policy rule create
Learn more
id |
integer |
path |
True |
Export Policy ID |
Request Body
| Name | Type | Description |
id |
integer |
Export Policy ID |
name |
string |
Export Policy Name |
rules |
array[export_rules] |
Rules of the Export Policy. |
svm |
Example request
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"ntfs_unix_security": "string",
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703950 |
Failed to rename ruleset |
1703952 |
Invalid ruleset name provided. No spaces are allowed in a ruleset name |
href |
string |
_links
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rules
allow_device_creation |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
ntfs_unix_security |
string |
NTFS export UNIX security options. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm
name |
string |
The name of the SVM. |
uuid |
string |
export_policy
id |
integer |
Export Policy ID |
name |
string |
rules |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
