REST API reference
Update export policy properties
Updates the properties of an export policy to modify its name or replace all associated rules. This is useful when you need to adjust access configurations for exported resources.
HTTP method and endpoint
PATCH /protocols/nfs/export-policies/{id}
Introduced in
ONTAP 9.6
Usage notes
Updates the properties of an export policy to change an export policy name or replace all export policy rules.
  • vserver export-policy rename
  • vserver export-policy rule delete
  • vserver export-policy rule create
id
integer
path
True
Export Policy ID
Request Body
Name Type Description
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rule]
Rules of the Export Policy.
svm
svm
Example request
  "id": 0,
  "name": "string",
  "rules": [
      "anonymous_user": "string",
      "chown_mode": "string",
      "clients": [
          "match": "0.0.0.0/0"
      "index": 0,
      "ntfs_unix_security": "string",
      "protocols": [
        "string"
      "ro_rule": [
        "string"
      "rw_rule": [
        "string"
      "superuser": [
        "string"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1703950
Failed to rename ruleset
1703952
Invalid ruleset name provided. No spaces are allowed in a ruleset name
string
export_client
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rule
allow_device_creation
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_client]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
name
string
The name of the SVM.
uuid
string
export_policy
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rule]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
