REST API reference
Update quota policy rule properties
Updates the properties of a specific quota policy rule to adjust its settings as needed. Use this capability to modify quota limits directly within the filesystem, ensuring that quota management aligns with your storage requirements.
HTTP method and endpoint
PATCH /storage/quota/rules/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Important notes:
  • The quota resize functionality is supported with the PATCH operation.
  • Quota resize allows you to modify the quota limits, directly in the filesystem.
  • The quota must be enabled on a FlexVol or a FlexGroup volume for quota resize to take effect.
  • If the quota is disabled on the volume, the quota policy rule PATCH API modifies the rule, but this does not affect the limits in the filesystem.
  • quota policy rule modify
  • quota resize
uuid
string
path
True
Rule UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
files
files
space
space
user_mapping
boolean
This parameter enables user mapping for user quota policy rules. This is valid in POST or PATCH for user quota policy rules only.
uuid
string
Unique identifier for the quota policy rule. This field is generated when the quota policy rule is created.
Example request
  "uuid": "5f1d13a7-f401-11e8-ac1a-005056a7c3b9"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
5308501
Mapping from Windows user to UNIX user for user rule was unsuccessful.
5308502
Mapping from UNIX user to Windows user for user rule was unsuccessful.
5308545
The specified quota rule UUID is invalid.
5308561
Failed to obtain volume quota state or invalid quota state obtained for volume.
5308567
Quota policy rule modify operation succeeded, but quota resize failed due to internal error.
5308573
Input value is greater than limit for field.
5308574
Input value is out of range for field.
5308575
Input value is incorrectly larger than listed field.
string
files
hard_limit
integer
This parameter specifies the hard limit for files. This is valid in POST or PATCH.
soft_limit
integer
This parameter specifies the soft limit for files. This is valid in POST or PATCH.
group
This parameter specifies the target group to which the group quota policy rule applies. This parameter takes a group name or identifier. This parameter is only valid for the POST operation of a group quota policy rule. The POST operation will fail with an appropriate error if this parameter is used as an input to create a user or a tree quota policy rule. This input parameter for POST takes either a group name or a group identifier, but not both. For default quota rules, the group name must be chosen and should be specified as "". For explicit group quota rules, this parameter can contain a UNIX group name or a UNIX group identifier.
id
string
Quota target group ID
name
string
Quota target group name
qtree
This parameter specifies the target qtree to which the user/group/tree quota policy rule applies. For a user/group quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST. For a user/group quota policy rule at volume level, this parameter is not valid in GET or POST. For a tree quota policy rule, this parameter is mandatory and is valid in both POST and GET. For a default tree quota policy rule, this parameter needs to be specified as "". For a tree quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST.
id
integer
The unique identifier for a qtree.
name
string
The name of the qtree.
space
hard_limit
integer
This parameter specifies the space hard limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.
soft_limit
integer
This parameter specifies the space soft limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit.
svm
name
string
The name of the SVM.
uuid
string
users
id
string
Quota target user ID
name
string
Quota target user name
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
quota_rule
files
files
space
space
user_mapping
boolean
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
