Update quota policy rule properties
Updates the properties of a specific quota policy rule to adjust quota limits directly in the filesystem. This operation is useful when managing storage resources on FlexVol or FlexGroup volumes with enabled quotas.
HTTP method and endpoint
PATCH /storage/quota/rules/{uuid}
Introduced in
ONTAP 9.7
Usage notes
Important notes:
The quota resize functionality is supported with the PATCH operation.
Quota resize allows you to modify the quota limits, directly in the filesystem.
The quota must be enabled on a FlexVol or a FlexGroup volume for
quota resizeto take effect. -
If the quota is disabled on the volume, the quota policy rule PATCH API modifies the rule, but this does not affect the limits in the filesystem.
Related ONTAP commands
quota policy rule modify -
quota resize
uuid |
string |
path |
True |
Rule UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
files |
space |
user_mapping |
boolean |
This parameter enables user mapping for user quota policy rules. This is valid in POST or PATCH for user quota policy rules only. |
uuid |
string |
Unique identifier for the quota policy rule. This field is generated when the quota policy rule is created. |
Example request
"uuid": "5f1d13a7-f401-11e8-ac1a-005056a7c3b9"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5308501 |
Mapping from Windows user to UNIX user for user rule was unsuccessful. |
5308502 |
Mapping from UNIX user to Windows user for user rule was unsuccessful. |
5308545 |
The specified quota rule UUID is invalid. |
5308561 |
Failed to obtain volume quota state or invalid quota state obtained for volume. |
5308567 |
Quota policy rule modify operation succeeded, but quota resize failed due to internal error. |
5308573 |
Input value is greater than limit for field. |
5308574 |
Input value is out of range for field. |
5308575 |
Input value is incorrectly larger than listed field. |
href |
string |
_links
files
hard_limit |
integer |
This parameter specifies the hard limit for files. This is valid in POST or PATCH. |
soft_limit |
integer |
This parameter specifies the soft limit for files. This is valid in POST or PATCH. |
group
This parameter specifies the target group to which the group quota policy rule applies. This parameter takes a group name or identifier. This parameter is only valid for the POST operation of a group quota policy rule. The POST operation will fail with an appropriate error if this parameter is used as an input to create a user or a tree quota policy rule. This input parameter for POST takes either a group name or a group identifier, but not both. For default quota rules, the group name must be chosen and should be specified as "". For explicit group quota rules, this parameter can contain a UNIX group name or a UNIX group identifier.
id |
string |
Quota target group ID |
name |
string |
Quota target group name |
qtree
This parameter specifies the target qtree to which the user/group/tree quota policy rule applies. For a user/group quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST. For a user/group quota policy rule at volume level, this parameter is not valid in GET or POST. For a tree quota policy rule, this parameter is mandatory and is valid in both POST and GET. For a default tree quota policy rule, this parameter needs to be specified as "". For a tree quota policy rule at qtree level, this parameter takes a qtree name and is valid in GET or POST.
id |
integer |
The unique identifier for a qtree. |
name |
string |
The name of the qtree. |
space
hard_limit |
integer |
This parameter specifies the space hard limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit. |
soft_limit |
integer |
This parameter specifies the space soft limit, in bytes. If less than 1024 bytes, the value is rounded up to 1024 bytes. Valid in POST or PATCH. For a POST operation where the parameter is either empty or set to -1, no limit is applied. For a PATCH operation where a limit is configured, use a value of -1 to clear the limit. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
users
id |
string |
Quota target user ID |
name |
string |
Quota target user name |
volume
name |
string |
The name of the volume. |
uuid |
string |
quota_rule
files |
space |
user_mapping |
boolean |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
