Update a shelf location LED
Updates the shelf location LED to reflect the current status or condition of the shelf. This is typically useful for maintenance or identification purposes.
HTTP method and endpoint
PATCH /storage/shelves/{uid}
Introduced in
ONTAP 9.10
Related ONTAP commands
storage shelf location-led modify
Learn more
uid |
string |
path |
True |
Shelf UID |
Request Body
| Name | Type | Description |
connection_type |
string |
disk_count |
integer |
id |
string |
internal |
boolean |
local |
boolean |
location_led |
string |
model |
string |
module_type |
string |
name |
string |
serial_number |
string |
state |
string |
uid |
string |
Example request
"connection_type": "sas",
"disk_count": 12,
"id": "1",
"location_led": "off",
"model": "DS2246",
"module_type": "iom6",
"name": "1.1",
"serial_number": "SHFMS1514000895",
"state": "ok",
"uid": "7777841915827391056"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
17825872 |
Shelf locate request failed because shelf " |
17825873 |
17825874 |
Shelf locate request failed for shelf " |
17825875 |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
error
Error object is populated when connection_state becomes non-optimal
severity |
string |
type |
string |
href |
string |
_links
node
name |
string |
uuid |
string |
acps
address |
string |
channel |
string |
connection_state |
string |
enabled |
boolean |
error |
Error object is populated when connection_state becomes non-optimal |
netmask |
string |
node |
port |
string |
subnet |
string |
bays
has_disk |
boolean |
id |
integer |
state |
string |
type |
string |
current_sensors
current |
integer |
Current, in milliamps |
id |
integer |
location |
string |
state |
string |
drawers
closed |
boolean |
disk_count |
integer |
error |
string |
id |
integer |
part_number |
string |
serial_number |
string |
state |
string |
errors
fans
id |
integer |
location |
string |
rpm |
integer |
state |
string |
psu
crest_factor |
integer |
The ratio of the peak voltage to the root-mean-square voltage |
model |
string |
power_drawn |
integer |
Power drawn, in watts |
power_rating |
integer |
Power rating, in watts |
frus
firmware_version |
string |
id |
integer |
installed |
boolean |
part_number |
string |
psu |
serial_number |
string |
state |
string |
type |
string |
manufacturer
name |
string |
paths
Storage port
name |
string |
node |
cable
identifier |
string |
length |
string |
part_number |
string |
serial_number |
string |
remote
chassis |
string |
device |
string |
mac_address |
string |
phy |
string |
port |
string |
wwn |
string |
ports
cable |
designator |
string |
id |
integer |
internal |
boolean |
mac_address |
string |
module_id |
string |
remote |
state |
string |
wwn |
string |
high
critical |
integer |
High critical threshold, in degrees Celsius |
warning |
integer |
High warning threshold, in degrees Celsius |
low
critical |
integer |
Low critical threshold, in degrees Celsius |
warning |
integer |
Low warning threshold, in degrees Celsius |
threshold
high |
low |
temperature_sensors
ambient |
boolean |
Sensor that measures the ambient temperature |
id |
integer |
location |
string |
state |
string |
temperature |
integer |
Temperature, in degrees Celsius |
threshold |
vendor
manufacturer |
string |
Support for this field will be removed in a future release. Please use vendor.name for this field. |
name |
string |
part_number |
string |
Part number |
product |
string |
Product name |
serial_number |
string |
Serial number |
voltage_sensors
id |
integer |
location |
string |
state |
string |
voltage |
number |
Voltage, in volts |
shelf
connection_type |
string |
disk_count |
integer |
id |
string |
internal |
boolean |
local |
boolean |
location_led |
string |
model |
string |
module_type |
string |
name |
string |
serial_number |
string |
state |
string |
uid |
string |
