REST API reference
Update a shelf location LED
Updates a shelf location LED to change its status or behavior as needed for maintenance or identification purposes.
HTTP method and endpoint
PATCH /storage/shelves/{uid}
Introduced in
ONTAP 9.10
  • storage shelf location-led modify
uid
string
path
True
Shelf UID
Request Body
Name Type Description
acps
array[acps]
Alternate Control Paths to ACP processors/functions in shelf modules and expanders
connection_type
string
current_sensors
array[current_sensors]
disk_count
integer
drawers
array[drawers]
fans
array[fans]
frus
array[frus]
id
string
internal
boolean
local
boolean
location_led
string
manufacturer
manufacturer
model
string
module_type
string
name
string
paths
array[paths]
serial_number
string
state
string
temperature_sensors
array[temperature_sensors]
uid
string
vendor
vendor
voltage_sensors
array[voltage_sensors]
Example request
  "acps": [
      "address": "192.168.1.104",
      "channel": "out_of_band",
      "connection_state": "full_connectivity",
      "error": {
        "severity": "string",
        "type": "string"
      "netmask": "255.255.252.0",
      "node": {
        "name": "node1",
      "port": "e0P",
      "subnet": "192.168.0.1"
  "connection_type": "sas",
  "current_sensors": [
      "current": 14410,
      "id": 1,
      "installed": 1,
      "location": "rear of the shelf on the lower left power supply",
      "state": "ok"
  "disk_count": 12,
  "drawers": [
      "disk_count": 12,
      "error": "string",
      "part_number": "111-03071",
      "serial_number": "021604008263",
      "state": "ok"
  "fans": [
      "id": 1,
      "installed": 1,
      "rpm": 3020,
      "state": "ok"
  "frus": [
      "firmware_version": "0191",
      "installed": 1,
      "part_number": "111-00690+A2",
      "psu": {
        "crest_factor": 92,
        "model": "00",
        "power_drawn": 210,
        "power_rating": 1600
      "serial_number": "8000166294",
      "state": "error",
      "type": "module"
  "id": "1",
  "location_led": "off",
  "manufacturer": {
    "name": "NETAPP"
  "model": "DS2246",
  "module_type": "iom6",
  "name": "1.1",
  "paths": [
      "name": "2a",
      "node": {
        "name": "node1",
  "serial_number": "SHFMS1514000895",
  "state": "ok",
  "temperature_sensors": [
      "ambient": "",
      "id": 1,
      "installed": 1,
      "location": "temp sensor on midplane left",
      "state": "ok",
      "temperature": 32,
      "threshold": {
        "high": {
          "critical": 60,
          "warning": 55
        "low": {
          "critical": 0,
          "warning": 5
  "uid": "7777841915827391056",
  "vendor": {
    "manufacturer": "XYZ",
    "name": "XYZ",
    "part_number": "A92831142733",
    "product": "LS2246",
    "serial_number": "891234572210221"
  "voltage_sensors": [
      "id": 1,
      "installed": 1,
      "state": "ok",
      "voltage": 12.18
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
17825872
Shelf locate request failed because shelf "\" was not found.
17825873
Shelf locate request failed because shelf "\" does not support this command.
17825874
Shelf locate request failed for shelf "\" with an unknown error.
17825875
Shelf locate request failed for shelf "\" because shelf modules are unreachable.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
error
Error object is populated when connection_state becomes non-optimal
severity
string
type
string
string
node
name
string
uuid
string
acps
address
string
channel
string
connection_state
string
enabled
boolean
error
error
netmask
string
node
node
port
string
subnet
string
drawer
id
integer
The drawer containing this bay
slot
integer
The drawer slot for this bay
bays
drawer
drawer
has_disk
boolean
id
integer
state
string
type
string
current_sensors
current
integer
Current, in milliamps
id
integer
installed
boolean
location
string
state
string
drawers
closed
boolean
disk_count
integer
error
string
id
integer
part_number
string
serial_number
string
state
string
errors
fans
id
integer
installed
boolean
location
string
rpm
integer
state
string
psu
crest_factor
integer
The ratio of the peak voltage to the root-mean-square voltage
model
string
power_drawn
integer
Power drawn, in watts
power_rating
integer
Power rating, in watts
frus
firmware_version
string
id
integer
installed
boolean
part_number
string
psu
psu
serial_number
string
state
string
type
string
manufacturer
name
string
paths
Storage port
name
string
node
node
cable
identifier
string
length
string
part_number
string
serial_number
string
remote
chassis
string
device
string
mac_address
string
phy
string
port
string
wwn
string
ports
cable
cable
designator
string
id
integer
internal
boolean
mac_address
string
module_id
string
remote
remote
state
string
wwn
string
high
critical
integer
High critical threshold, in degrees Celsius
warning
integer
High warning threshold, in degrees Celsius
low
critical
integer
Low critical threshold, in degrees Celsius
warning
integer
Low warning threshold, in degrees Celsius
threshold
high
high
low
low
temperature_sensors
ambient
boolean
Sensor that measures the ambient temperature
id
integer
installed
boolean
location
string
state
string
temperature
integer
Temperature, in degrees Celsius
threshold
threshold
vendor
manufacturer
string
Support for this field will be removed in a future release. Please use vendor.name for this field.
name
string
part_number
string
Part number
product
string
Product name
serial_number
string
Serial number
voltage_sensors
id
integer
installed
boolean
location
string
state
string
voltage
number
Voltage, in volts
shelf
acps
array[acps]
connection_type
string
current_sensors
disk_count
integer
drawers
array[drawers]
fans
array[fans]
frus
array[frus]
id
string
internal
boolean
local
boolean
location_led
string
manufacturer
manufacturer
model
string
module_type
string
name
string
paths
array[paths]
serial_number
string
state
string
temperature_sensors
uid
string
vendor
vendor
voltage_sensors
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
