Modify the configuration for an automatic update
Updates the configuration for a specific automatic update, adjusting settings as needed for scheduled operations.
HTTP method and endpoint
PATCH /support/auto-update/configurations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Updates the configuration for a specified automatic update.
uuid |
string |
path |
True |
Unique identifier for configuration record. |
Request Body
| Name | Type | Description |
action |
string |
The action to be taken by the alert source as specified by the user. |
category |
string |
Category for the configuration row. |
description |
Description of the configuration row. ONTAP Message Codes Code — Description 131072401 — Storage Firmware 131072402 — SP/BMC Firmware |
uuid |
string |
Unique identifier for the configuration row. |
Example request
"action": "confirm",
"category": "disk_fw",
"description": {
"code": "string",
"message": "string"
"uuid": "572361f3-e769-439d-9c04-2ba48a08ff47"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262179 |
Unexpected argument. |
href |
string |
_links
description
131072401 |
Storage Firmware |
131072402 |
SP/BMC Firmware |
code |
string |
Argument code |
message |
string |
Message argument |
auto_update_configuration
action |
string |
category |
string |
description |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
