REST API reference
Modify the configuration for an automatic update
Updates the configuration for a specific automatic update, adjusting its settings as needed for your system's requirements.
HTTP method and endpoint
PATCH /support/auto-update/configurations/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Updates the configuration for a specified automatic update.
uuid
string
path
True
Unique identifier for configuration record.
Request Body
Name Type Description
_links
_links
action
string
The action to be taken by the alert source as specified by the user.
category
string
Category for the configuration row.
description
description
Description of the configuration row.
ONTAP Message Codes
Code — Description
131072401 — Storage Firmware
131072402 — SP/BMC Firmware
uuid
string
Unique identifier for the configuration row.
Example request
  "action": "confirm",
  "category": "disk_fw",
  "description": {
    "code": "string",
    "message": "string"
  "uuid": "572361f3-e769-439d-9c04-2ba48a08ff47"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262179
Unexpected argument.
string
description
Description of the configuration row. ONTAP Message Codes
Code Description
131072401
Storage Firmware
131072402
SP/BMC Firmware
code
string
Argument code
message
string
Message argument
auto_update_configuration
_links
_links
action
string
category
string
description
description
ONTAP Message Codes
Code — Description
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
