REST API reference
Update an event filter
Updates an event filter to modify its criteria or identifier, ensuring it aligns with your current event management needs.
HTTP method and endpoint
PATCH /support/ems/filters/{name}
Introduced in
ONTAP 9.6
  • new_name - New string that uniquely identifies a filter.
  • rules - New list of criteria used to match the filter with an event. The existing list is discarded.
  • event filter rename
  • event filter rule add
  • event filter rule delete
  • event filter rule reorder
name
string
path
True
Filter name
new_name
string
query
False
New filter name for renames. Valid in PATCH.
Request Body
Name Type Description
name
string
Filter name
rules
array[rules]
Array of event filter rules on which to match.
system_defined
boolean
Flag indicating system-defined filters.
Example request
  "name": "snmp-traphost",
  "rules": [
      "index": 1,
      "message_criteria": {
        "name_pattern": "callhome.*",
        "severities": "error,informational",
        "snmp_trap_types": "standard|built_in"
      "type": "include"
  "system_defined": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983088
The filter name provided is empty
983089
The filter name provided cannot contain spaces
983092
The index of the rule provided is outside the allowed range for the filter provided
983094
The filter name provided is invalid. The filter name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or (underscore). The allowed special characters are (underscore) and -(hyphen)
983095
The rule index provided is invalid for the filter provided
983101
No event is matched by the rule provided
983113
Default filters cannot be modified or removed
983114
The maximum number of filters is reached
983115
The maximum number of filter rules is reached
983126
A rule requires at least one of name_pattern, severities or snmp-trap-types to be defined
983127
A property cannot contain a combination of the wildcard characters and other values
983128
An invalid value is provided for the property 'snmp_trap_types'
983146
An invalid value is provided for the property 'severities'
983147
The severity levels provided are not supported
983155
The provided severities property does not match that of the name_pattern
983156
The provided snmp_trap_types property does not match that of the name_pattern
983157
The provided severities and snmp_trap_types do not match those of the name_pattern
983158
The name_pattern provided does not exist
string
message_criteria
Matching message definitions for the filter. A property must be specified.
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
rules
Rule for an event filter
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
type
string
Rule type
ems_filter
name
string
Filter name
rules
array[rules]
system_defined
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
