Update an event filter
Updates an event filter to change its name or adjust the criteria that determine which events it matches. This helps you refine how events are captured and categorized according to your needs.
HTTP method and endpoint
PATCH /support/ems/filters/{name}
Introduced in
ONTAP 9.6
Recommended optional properties
new_name- New string that uniquely identifies a filter. -
rules- New list of criteria used to match the filter with an event. The existing list is discarded.
Related ONTAP commands
event filter create -
event filter delete -
event filter rename -
event filter rule add -
event filter rule delete -
event filter rule reorder
name |
string |
path |
True |
Filter name |
new_name |
string |
query |
False |
New filter name for renames. Valid in PATCH. |
Request Body
| Name | Type | Description |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
Example request
"name": "snmp-traphost",
"rules": [
"index": "1",
"message_criteria": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The filter name provided is empty |
983089 |
The filter name provided cannot contain spaces |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983094 |
The filter name provided is invalid. The filter name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or (underscore). The allowed special characters are (underscore) and -(hyphen) |
983095 |
The rule index provided is invalid for the filter provided |
983101 |
No event is matched by the rule provided |
983113 |
Default filters cannot be modified or removed |
983114 |
The maximum number of filters is reached |
983115 |
The maximum number of filter rules is reached |
983126 |
A rule requires at least one of name_pattern, severities or snmp-trap-types to be defined |
983127 |
A property cannot contain a combination of the wildcard characters and other values |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severity levels provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
href |
string |
_links
message_criteria
Matching message definitions for the filter. A property must be specified.
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
rules
Rule for an event filter
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
ems_filter
name |
string |
Filter name |
rules |
array[rules] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
