Start MetroCluster diagnostics or set up a periodic diagnostic schedule
Initiates a MetroCluster diagnostic operation or establishes a schedule for regular diagnostics to ensure system health and performance.
HTTP method and endpoint
POST /cluster/metrocluster/diagnostics
Introduced in
ONTAP 9.8
Usage notes
Start a MetroCluster diagnostic operation or set up a schedule for the diagnostics to be run periodically.
schedule |
integer |
query |
False |
Shows the minutes of every hour when a job runs. Setting this parameter schedules the periodic job to be run to perform MetroCluster diagnostic. |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2427132 |
MetroCluster is not configured on this cluster. |
2432833 |
Operation is already running. |
2432852 |
MetroCluster diagnostics start |
2432853 |
MetroCluster diagnostics job scheduled |
2432854 |
MetroCluster diagnostics complete |
2432855 |
MetroCluster diagnostics operation failed. Use the REST API GET method on "/api/cluster/metrocluster/operations?type=check&fields=*" for more information. |
href |
string |
_links
job_link
uuid |
string |
