REST API reference
Start MetroCluster diagnostics or set up a periodic diagnostic schedule
POST /cluster/metrocluster/diagnostics
Introduced In: 9.8
Start a MetroCluster diagnostic operation or set up a schedule for the diagnostics to be run periodically.
schedule
integer
query
False
Shows the minutes of every hour when a job runs. Setting this parameter schedules the periodic job to be run to perform MetroCluster diagnostic.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2427132
MetroCluster is not configured on this cluster.
2432833
Operation is already running.
2432852
MetroCluster diagnostics start
2432853
MetroCluster diagnostics job scheduled
2432854
MetroCluster diagnostics complete
2432855
MetroCluster diagnostics operation failed. Use the REST API GET method on "/api/cluster/metrocluster/operations?type=check&fields=*" for more information.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
