Set up a MetroCluster configuration
Sets up a MetroCluster configuration to establish a high-availability environment across geographically separated clusters. This can enhance data resiliency and ensure continuous operation in case of site failures.
HTTP method and endpoint
POST /cluster/metrocluster
Introduced in
ONTAP 9.8
Required properties
partner_cluster.name -
dr_pairs
Recommended optional properties
mediator.*
Learn more
Related ONTAP commands
metrocluster configuration-settings dr-group create -
metrocluster configuration-settings interface create -
metrocluster configuration-settings connection connect -
metrocluster configuration-settings mediator add -
storage aggregate create -
storage aggregate mirror -
metrocluster configure
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
dr_pairs |
array[dr_pairs] |
DR Pairs to create as part of a MetroCluster configure. |
enabled |
boolean |
local |
mccip_ports |
array[mccip_ports] |
List of Port specifications. |
mediator |
Mediator information |
partner_cluster |
Partner cluster information. |
remote |
Example request
"dr_pairs": [
"node": {
"name": "node1",
"partner": {
"name": "node1",
"local": {
"cluster": {
"name": "cluster1",
"configuration_state": "string",
"mode": "string"
"mccip_ports": [
"l3_config": {
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"name": "e1b",
"node": {
"name": "node1",
"uuid": "string",
"vlan_id": 200
"mediator": {
"ca_certificate": "string",
"dr_group": {
"id": 0
"ip_address": "10.10.10.7",
"password": "mypassword",
"peer_cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"peer_mediator_connectivity": "connected",
"port": 31784,
"reachable": 1,
"user": "myusername",
"uuid": "string"
"partner_cluster": {
"name": "cluster1",
"remote": {
"cluster": {
"name": "cluster1",
"mode": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2432832 |
Required environment variables are not set. |
2432833 |
Operation is already running. |
2432834 |
MetroCluster is already configured. |
2432835 |
Operation not supported. |
2432836 |
There are not enough disks in Pool1. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2432839 |
Required parameters not set. |
2432840 |
Configuring DR Groups |
2432841 |
Generating IP addresses |
2432843 |
Running Aggregate Recommender |
2432844 |
Checking remote storage pool |
2432845 |
Mirroring aggregates |
2432846 |
Configuring MetroCluster and DR mirroring |
2432848 |
Setting up MetroCluster |
2432849 |
MetroCluster setup is complete |
2432851 |
Minimum number of required data aggregates for MetroCluster configuration are still not mirrored. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
href |
string |
self_link
_links
node
Local node of the DR Group.
name |
string |
uuid |
string |
partner
Partner node of the DR Group.
name |
string |
uuid |
string |
dr_pairs
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
cluster
name |
string |
uuid |
string |
local
cluster |
configuration_state |
string |
Indicates the state of the local cluster configuration. |
mode |
string |
Specifies the mode of operation of the local cluster. |
partner_cluster_reachable |
boolean |
Specifies whether the partner cluster is reachable from the local cluster. |
periodic_check_enabled |
boolean |
Indicates whether or not a periodic check is enabled on the local cluster. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
l3_config
ipv4_interface |
Object to setup an interface along with its default router. |
node
Node information
name |
string |
uuid |
string |
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config |
name |
string |
Port name |
node |
Node information |
uuid |
string |
Port UUID |
vlan_id |
integer |
VLAN ID |
dr_group
DR group reference.
id |
integer |
DR Group ID |
peer_cluster
The peer cluster that the mediator service is used for.
name |
string |
uuid |
string |
mediator
ca_certificate |
string |
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
password |
string |
The password used to connect to the REST server on the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
user |
string |
The username used to connect to the REST server on the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
partner_cluster
name |
string |
uuid |
string |
remote
cluster |
string |
Indicates the state of the remote cluster configuration. |
mode |
string |
Specifies the mode of operation of the remote cluster. |
boolean |
Indicates whether or not a periodic check is enabled on the remote cluster. |
metrocluster
Holds MetroCluster status and configuration parameters for the local and remote clusters. REST: /api/cluster/metrocluster
dr_pairs |
array[dr_pairs] |
enabled |
boolean |
local |
mccip_ports |
mediator |
partner_cluster |
remote |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
