REST API reference
Set up a MetroCluster configuration
Sets up a MetroCluster configuration, enabling high availability and disaster recovery across geographically separated sites.
HTTP method and endpoint
POST /cluster/metrocluster
Introduced in
ONTAP 9.8
Required properties
  • partner_cluster.name
  • dr_pairs
  • mediator.*
  • mccip_ports
  • metrocluster configuration-settings dr-group create
  • metrocluster configuration-settings interface create
  • metrocluster configuration-settings connection connect
  • metrocluster configuration-settings mediator add
  • storage aggregate create
  • storage aggregate mirror
  • metrocluster configure
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
configuration_type
string
Displays the MetroCluster configuration type.
dr_pairs
array[dr_pairs]
DR Pairs to create as part of a MetroCluster configure.
local
local
mccip_ports
array[mccip_ports]
List of Port specifications.
mediator
mediator
Mediator information
partner_cluster
partner_cluster
Partner cluster information.
remote
remote
Example request
  "configuration_type": "string",
  "dr_pairs": [
      "node": {
        "name": "node1",
      "partner": {
        "name": "node1",
  "local": {
    "cluster": {
      "name": "cluster1",
    "configuration_state": "string",
    "mode": "string"
  "mccip_ports": [
      "l3_config": {
        "ipv4_interface": {
          "address": "10.10.10.7",
          "gateway": "10.1.1.1",
          "netmask": "24"
      "name": "e1b",
      "node": {
        "name": "node1",
      "uuid": "string",
      "vlan_id": 200
  "mediator": {
    "ca_certificate": "string",
    "dr_group": {
      "id": 0
    "ip_address": "10.10.10.7",
    "password": "mypassword",
    "peer_cluster": {
      "name": "cluster2",
      "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
    "peer_mediator_connectivity": "connected",
    "port": 31784,
    "reachable": 1,
    "user": "myusername",
    "uuid": "string"
  "partner_cluster": {
    "name": "cluster1",
  "remote": {
    "cluster": {
      "name": "cluster1",
    "mode": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2432832
Required environment variables are not set.
2432833
Operation is already running.
2432834
MetroCluster is already configured.
2432835
Operation not supported.
2432836
There are not enough disks in Pool1. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2432839
Required parameters not set.
2432840
Configuring DR Groups
2432841
Generating IP addresses
2432843
Running Aggregate Recommender
2432844
Checking remote storage pool
2432845
Mirroring aggregates
2432846
Configuring MetroCluster and DR mirroring
2432848
Setting up MetroCluster
2432849
MetroCluster setup is complete
2432851
Minimum number of required data aggregates for MetroCluster configuration are still not mirrored. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
string
node
Local node of the DR Group.
name
string
uuid
string
partner
Partner node of the DR Group.
name
string
uuid
string
dr_pairs
node
node
partner
partner
cluster
name
string
uuid
string
local
cluster
cluster
configuration_state
string
Indicates the state of the local cluster configuration.
mode
string
Specifies the mode of operation of the local cluster.
partner_cluster_reachable
boolean
Specifies whether the partner cluster is reachable from the local cluster.
periodic_check_enabled
boolean
Indicates whether or not a periodic check is enabled on the local cluster.
ipv4_interface
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
l3_config
ipv4_interface
ipv4_interface
node
Node information
name
string
uuid
string
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config
l3_config
name
string
Port name
node
node
Node information
uuid
string
Port UUID
vlan_id
integer
VLAN ID
dr_group
DR group reference.
id
integer
DR Group ID
peer_cluster
The peer cluster that the mediator service is used for.
_links
_links
name
string
uuid
string
mediator
ca_certificate
string
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
  • x-ntap-createOnly: true
  • Introduced in: 9.8
  • x-nullable: true
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
password
string
The password used to connect to the REST server on the mediator.
peer_cluster
peer_cluster
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
user
string
The username used to connect to the REST server on the mediator.
uuid
string
The unique identifier for the mediator service.
partner_cluster
name
string
uuid
string
remote
cluster
cluster
configuration_state
string
Indicates the state of the remote cluster configuration.
mode
string
Specifies the mode of operation of the remote cluster.
boolean
Indicates whether or not a periodic check is enabled on the remote cluster.
metrocluster
Holds MetroCluster status and configuration parameters for the local and remote clusters. REST: /api/cluster/metrocluster
configuration_type
string
dr_pairs
array[dr_pairs]
local
local
mccip_ports
array[mccip_ports]
mediator
mediator
partner_cluster
partner_cluster
remote
remote
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
