Create the CIFS domain preferred DC configuration for an SVM
Configures a preferred domain controller (DC) for a CIFS domain within a specific SVM. This setup helps ensure optimal domain controller selection and performance for CIFS operations.
HTTP method and endpoint
POST /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.10
Usage notes
Creates a CIFS preferred DC configuration for an SVM.
Important notes
In the case of bulk POST requests, the create operation should be performed serially since there can be interdependence between records. In order to avoid issues, it is advisable to always use the query parameter "serial_records=true".
Required properties
svm.uuid- Existing SVM in which to create the preferred-dc. -
domain- Fully Qualified Domain Name. -
server_ip- IPv4/IPv6 address of the Preferred Domain Controller.
The following parameters are optional:
skip_config_validation
Related ONTAP commands
vserver cifs domain preferred-dc add
skip_config_validation |
boolean |
query |
False |
Skip the validation of the specified preferred DC configuration.
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
fqdn |
string |
Fully Qualified Domain Name. |
server_ip |
string |
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address. |
Example request
"fqdn": "test.com",
"server_ip": "4.4.4.4"
Status: 201, Created
fqdn |
string |
server_ip |
string |
"fqdn": "test.com",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621516 |
Only data SVMs allowed. |
655918 |
The fully qualified domain name cannot be longer than 254 bytes. |
656408 |
RPC failure occured during the CIFS preferred-dc configuration validation. |
656407 |
Failed to validate CIFS preferred-dc for domain. Reason: Configuration not found at SecD. Contact technical support for assistance. |
655366 |
Invalid domain controller. |
655506 |
Failed to add preferred-dc. |
cifs_domain_preferred_dc
fqdn |
string |
server_ip |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
