REST API reference
Create the CIFS domain preferred DC configuration for an SVM
Creates a CIFS domain preferred DC configuration for an SVM. This helps you designate a specific domain controller as preferred for handling authentication and directory requests, optimizing domain interactions for the SVM.
HTTP method and endpoint
POST /protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers
Introduced in
ONTAP 9.10
Usage notes
Creates a CIFS preferred DC configuration for an SVM.
Important notes
  • In the case of bulk POST requests, the create operation should be performed serially since there can be interdependence between records. In order to avoid issues, it is advisable to always use the query parameter "serial_records=true".
Required properties
  • svm.uuid - Existing SVM in which to create the preferred-dc.
  • domain - Fully Qualified Domain Name.
  • server_ip - IPv4/IPv6 address of the Preferred Domain Controller.
The following parameters are optional:
  • skip_config_validation
  • vserver cifs domain preferred-dc add
boolean
query
False
Skip the validation of the specified preferred DC configuration.
  • Default value:
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
fqdn
string
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
status
status
Status of CIFS preferred domain controller.
svm
svm
Example request
  "fqdn": "test.com",
  "server_ip": "4.4.4.4",
  "status": {
    "details": "Response time (msec): 111",
    "reachable": 1
  "svm": {
    "name": "svm1",
Status: 201, Created
fqdn
string
server_ip
string
status
status
svm
svm
  "fqdn": "test.com",
  "status": {
    "reachable": 1
  "svm": {
    "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621516
Only data SVMs allowed.
655918
The fully qualified domain name cannot be longer than 254 bytes.
656408
RPC failure occurred during the CIFS preferred-dc configuration validation.
656407
Failed to validate CIFS preferred-dc for domain. Reason: Configuration not found at SecD. Contact technical support for assistance.
655366
Invalid domain controller.
655506
Failed to add preferred-dc.
status
details
string
Provides a detailed description of the state if the state is 'down' or the response time of the DNS server if the state is 'up'.
reachable
boolean
Indicates whether or not the domain controller is reachable.
string
svm
name
string
uuid
string
cifs_domain_preferred_dc
fqdn
string
server_ip
string
status
status
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
