REST API reference
Add local users and Active Directory users and groups to a local group and SVM
Adds local users, Active Directory users, and groups to a specific local group and Storage Virtual Machine (SVM), expanding the membership list with new entries. Use this endpoint when you need to manage access permissions by updating user and group associations within your network's local groups.
HTTP method and endpoint
POST /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members
Introduced in
ONTAP 9.10
Usage notes
Adds local users, Active Directory users and Active Directory groups to the specified local group and SVM.
Important note
  • Specified members are appended to the existing list of members.
Required properties
  • svm.uuid or svm.name - Existing SVM for which members are added to local group.
  • local_cifs_group.sid - Security ID of the local group to which members are added.
  • name or records - Local users, Active Directory users, or Active Directory groups to be added to a particular local group.
  • vserver cifs users-and-groups local-group add-members
string
path
True
Local group SID
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
name
string
Local user, Active Directory user, or Active Directory group which is a member of the specified local group.
records
array[records]
An array of local users, Active Directory users, and Active Directory groups specified to add or delete multiple members to or from a local group in a single API call. Not allowed when the name property is used.
Example request
  "name": "string",
  "records": [
      "name": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
655673
Failed to resolve the member to be added to the specified group.
655718
Failed to add a member to the specified group. The error code returned details the failure along with the reason for the failure. Take corrective actions as per the specified reason.
655742
The "records" field must not be specified when a single user is added.
655743
SVM UUID and CIFS local group SID are invalid fields for the "records" parameter.
records
name
string
local_cifs_group_members
name
string
records
array[records]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
