Add local users and Active Directory users and groups to a local group and SVM
Adds local users, Active Directory users, and Active Directory groups to a specified local group and SVM. Use this to extend existing group memberships within your storage environment.
HTTP method and endpoint
POST /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members
Introduced in
ONTAP 9.10
Usage notes
Adds local users, Active Directory users and Active Directory groups to the specified local group and SVM.
Important note
Specified members are appended to the existing list of members.
Required properties
svm.uuidorsvm.name- Existing SVM for which members are added to local group. -
local_cifs_group.sid- Security ID of the local group to which members are added. -
nameorrecords- Local users, Active Directory users, or Active Directory groups to be added to a particular local group.
Related ONTAP commands
vserver cifs users-and-groups local-group add-members
local_cifs_group.sid |
string |
path |
True |
Local group SID |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
name |
string |
Local user, Active Directory user, or Active Directory group which is a member of the specified local group. |
records |
array[records] |
An array of local users, Active Directory users, and Active Directory groups specified to add or delete multiple members to or from a local group in a single API call.
Not allowed when the |
Example request
"name": "string",
"records": [
"name": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655673 |
Failed to resolve the member to be added to the specified group. |
655718 |
Failed to add a member to the specified group. The error code returned details the failure along with the reason for the failure. Take corrective actions as per the specified reason. |
655742 |
Records must not be specified when member name is specified. |
655743 |
SVM UUID and CIFS local group SID are invalid fields for the "records" parameter. |
655744 |
Either name or records must be specified. |
records
name |
string |
local_cifs_group_members
name |
string |
records |
array[records] |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
