REST API reference
Create a CIFS server
Creates a CIFS server within an existing SVM. This action sets up the server to integrate with a specified Windows Active Directory domain.
HTTP method and endpoint
POST /protocols/cifs/services
Introduced in
ONTAP 9.6
Usage notes
Each SVM can have one CIFS server.
Important notes
  • The CIFS server name might or might not be the same as the SVM name.
  • The CIFS server name can contain up to 15 characters.
  • The CIFS server name does not support the following characters: @ # * ( ) = + [ ] \| ; : " , < > / ?
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the CIFS server.
  • name - Name of the CIFS server.
  • ad_domain.fqdn - Fully qualified domain name of the Windows Active Directory to which this CIFS server belongs.
  • ad_domain.user - User account with the access to add the CIFS server to the Active Directory.
  • ad_domain.password - Account password used to add this CIFS server to the Active Directory.
  • comment - Add a text comment of up to 48 characters about the CIFS server.
  • netbios.aliases - Add a comma-delimited list of one or more NetBIOS aliases for the CIFS server.
  • netbios.wins_servers - Add a list of Windows Internet Name Server (WINS) addresses that manage and map the NetBIOS name of the CIFS server to their network IP addresses. The IP addresses must be IPv4 addresses.
Default property values
If not specified in POST, the following default property values are assigned:
  • ad_domain.organizational_unit - CN=Computers
  • enabled - true
  • restrict_anonymous - no_enumeration
  • smb_signing - false
  • smb_encryption - false
  • encrypt_dc_connection - false
  • kdc_encryption - false
  • default_unix_user - pcuser
  • netbios_enabled - false However, if either "netbios.wins-server" or "netbios.aliases" is set during POST and if netbios_enabled is not specified then netbios_enabled is set to true.
  • aes_netlogon_enabled - false
  • try_ldap_channel_binding - true
  • ldap_referral_enabled - false
  • vserver cifs server create
  • vserver cifs server options modify
  • vserver cifs security modify
  • vserver cifs server add-netbios-aliases
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ad_domain
ad_domain
comment
string
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks.
default_unix_user
string
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails.
enabled
boolean
Specifies if the CIFS service is administratively enabled.
metric
metric
name
string
The name of the CIFS server.
netbios
cifs_netbios
options
cifs_service_options
security
cifs_service_security
statistics
statistics
svm
svm
Example request
  "ad_domain": {
    "fqdn": "example.com",
    "organizational_unit": "string",
    "password": "string",
    "user": "string"
  "comment": "This CIFS Server Belongs to CS Department",
  "default_unix_user": "string",
  "metric": {
    "duration": "PT15S",
    "iops": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput": {
      "read": 200,
      "total": 1000,
      "write": 100
    "timestamp": "2017-01-25T11:20:13Z"
  "name": "CIFS1",
  "netbios": {
    "aliases": [
      "ALIAS_1",
      "ALIAS_2",
      "ALIAS_3"
    "wins_servers": [
      "10.224.65.20",
      "10.224.65.21"
  "options": {
    "null_user_windows_name": "string",
    "smb_credits": 128,
    "widelink_reparse_versions": [
      "smb1"
  "security": {
    "restrict_anonymous": "string",
    "session_security": "string"
  "statistics": {
    "iops_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "latency_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
    "status": "ok",
    "throughput_raw": {
      "read": 200,
      "total": 1000,
      "write": 100
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
4915251
STARTTLS and LDAPS cannot be used together.
string
ad_domain
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
password
string
The account password used to add this CIFS server to the Active Directory. This is not audited.
user
string
The user account used to add this CIFS server to the Active Directory.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
cifs_netbios
aliases
array[string]
enabled
boolean
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration.
wins_servers
array[string]
admin_to_root_mapping
boolean
Specifies whether or not Administrator can be mapped to the UNIX user "root".
advanced_sparse_file
boolean
Specifies whether or not the CIFS server supports the advanced sparse file capabilities. This allows CIFS clients to query the allocated ranges of a file and to write zeroes or free data blocks for ranges of a file.
copy_offload
boolean
Specifies whether or not to enable the Copy Offload feature. This feature enables direct data transfers within or between compatible storage devices without transferring the data through the host computer.
Note that this will also enable/disable the direct copy feature accordingly.
fake_open
boolean
Specifies whether or not fake open support is enabled. This parameter allows you to optimize the open and close requests coming from SMB 2 clients.
fsctl_trim
boolean
Specifies whether or not the trim requests (FSCTL_FILE_LEVEL_TRIM) are supported on the CIFS server.
junction_reparse
boolean
Specifies whether or not the reparse point support is enabled. When enabled the CIFS server exposes junction points to Windows clients as reparse points. This parameter is only active if the client has negotiated use of the SMB 2 or SMB 3 protocol. This parameter is not supported for SVMs with Infinite Volume.
large_mtu
boolean
Specifies whether or not SMB clients can send reads up to 1 MB in size.
multichannel
boolean
Specifies whether or not the CIFS server supports Multichannel.
string
Specifies a Windows User or Group name that should be mapped in case of a NULL user value.
path_component_cache
boolean
Specifies whether or not the path component cache is enabled on the CIFS server.
referral
boolean
Specifies whether or not to refer clients to more optimal LIFs. When enabled, it automatically refers clients to a data LIF local to the node which hosts the root of the requested share.
smb_credits
integer
Specifies the maximum number of outstanding requests on a CIFS connection.
array[string]
Specifies the CIFS protocol versions for which the widelink is reported as reparse point.
boolean
Specifies whether or not an AES session key is enabled for the Netlogon channel.
boolean
Specifies whether encryption is required for domain controller connections.
kdc_encryption
boolean
Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
  • RC4-HMAC
  • DES
  • AES When the CIFS server is created, the domain controller creates a computer machine account in Active Directory. After a newly created machine account authenticates, the KDC and the CIFS server negotiates encryption types. At this time, the KDC becomes aware of the encryption capabilities of the particular machine account and uses those capabilities in subsequent communication with the CIFS server. In addition to negotiating encryption types during CIFS server creation, the encryption types are renegotiated when a machine account password is reset.
boolean
Specifies whether or not LDAP referral chasing is enabled for AD LDAP connections.
restrict_anonymous
string
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
  • no_restriction - No access restriction for an anonymous user.
  • no_enumeration - Enumeration is restricted for an anonymous user.
  • no_access - All access is restricted for an anonymous user.
session_security
string
Specifies client session security for AD LDAP connections. The available values are:
  • none - No Signing or Sealing.
  • sign - Sign LDAP traffic.
  • seal - Seal and Sign LDAP traffic
smb_encryption
boolean
Specifies whether encryption is required for incoming CIFS traffic.
smb_signing
boolean
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised.
boolean
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.
use_ldaps
boolean
Specifies whether or not to use use LDAPS for secure Active Directory LDAP connections by using the TLS/SSL protocols.
use_start_tls
boolean
Specifies whether or not to use SSL/TLS for allowing secure LDAP communication with Active Directory LDAP servers.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
The name of the SVM.
uuid
string
cifs_service
ad_domain
ad_domain
comment
string
default_unix_user
string
enabled
boolean
metric
metric
name
string
netbios
cifs_netbios
options
security
statistics
statistics
svm
svm
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
