REST API reference
Create a CIFS server
Creates a CIFS server to enable file sharing over the CIFS protocol within a Storage Virtual Machine (SVM). This setup is essential for integrating your storage system with Windows Active Directory or workgroup environments, ensuring seamless access and management of shared resources.
HTTP method and endpoint
POST /protocols/cifs/services
Introduced in
ONTAP 9.6
Usage notes
Each SVM can have one CIFS server.
Important notes
  • The CIFS server name might or might not be the same as the SVM name.
  • The CIFS server name can contain up to 15 characters.
  • The CIFS server name does not support the following characters: @ # * ( ) = + [ ] \| ; : " , < > / ?
Required properties when creating CIFS server with Windows Active Directory domain
  • svm.uuid or svm.name - Existing SVM in which to create the CIFS server.
  • name - Name of the CIFS server.
  • ad_domain.fqdn - Fully qualified domain name of the Windows Active Directory to which this CIFS server belongs.
  • ad_domain.user - User account with the access to add the CIFS server to the Active Directory.
  • ad_domain.password - Account password used to add this CIFS server to the Active Directory.
Required properties when creating CIFS server in Workgroup mode
  • workgroup - Name of the workgroup to which this CIFS server belongs.
Required properties when using AKV for authentication (ANF platform)
  • client_id - Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId.
  • tenant_id - Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId.
  • key_vault_uri - URI of the deployed AKV that is used by ONTAP for storing keys.
  • authentication_method - Authentication method used by the application to prove its identity to AKV or EntraId. It can be either "client_secret" or "certificate".
  • auth_user_type - Type of user who can access the SMB Volume. It can be either "domain_user" or "hybrid_user". The default is domain_user. In the case of a hybrid-user, ONTAP cannot access on-premise ADDS.
  • client_secret - Secret used by the application to prove its identity to AKV.
  • client_certificate - Base64 encoded PKCS12 certificate used by the application to prove its identity to AKV.
  • comment - Add a text comment of up to 256 characters about the CIFS server.
  • netbios.aliases - Add a comma-delimited list of one or more NetBIOS aliases for the CIFS server.
  • netbios.wins_servers - Add a list of Windows Internet Name Server (WINS) addresses that manage and map the NetBIOS name of the CIFS server to their network IP addresses. The IP addresses must be IPv4 addresses.
Default property values
If not specified in POST, the following default property values are assigned:
  • ad_domain.organizational_unit - CN=Computers
  • enabled - true
  • security.restrict_anonymous - no_enumeration
  • security.smb_signing - false
  • security.smb_encryption - false
  • security.encrypt_dc_connection - false
  • default_unix_user - pcuser
  • netbios.enabled - false However, if either "netbios.wins-server" or "netbios.aliases" is set during POST and if netbios.enabled is not specified then netbios.enabled is set to true.
  • security.aes_netlogon_enabled - false
  • security.try_ldap_channel_binding - true
  • security.ldap_referral_enabled - false
  • vserver cifs server create
  • vserver cifs server options modify
  • vserver cifs security modify
  • vserver cifs server add-netbios-aliases
force
boolean
query
False
If this is set and a machine account with the same name as specified in 'cifs-server name' exists in the Active Directory, existing machine account will be overwritten and reused.
  • Introduced in: 9.11
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ad_domain
ad_domain
auth-style
string
Authentication type.
auth_user_type
string
Specifies the type of user who can access the SMB Volume. The default is domain_user. In the case of a hybrid-user, ONTAP won't contact on-premise ADDS.
  • enum: ["domain_user", "hybrid_user"]
  • Introduced in: 9.16
  • x-nullable: true
string
Specifies the authentication method. The available values are:
  • client_secret
  • certificate
client_certificate
string
client_id
string
client_secret
string
comment
string
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks.
default_unix_user
string
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails.
enabled
boolean
Specifies if the CIFS service is administratively enabled.
key_vault_uri
string
name
string
The name of the CIFS server.
netbios
cifs_netbios
oauth_host
string
Open authorization server host name.
options
cifs_service_options
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
security
cifs_service_security
svm
svm
tenant_id
string
timeout
integer
AKV connection timeout, in seconds. The allowed range is between 0 to 30 seconds.
verify_host
boolean
Verify the identity of the AKV host name. By default, verify_host is set to true.
workgroup
string
The workgroup name.
Example request
  "ad_domain": {
    "default_site": "string",
    "fqdn": "example.com",
    "organizational_unit": "string",
    "password": "string",
    "user": "string"
  "auth-style": "domain",
  "auth_user_type": "string",
  "authentication_method": "string",
  "client_certificate": "PEM Cert",
  "client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
  "client_secret": "<APPLICATION-CLIENT-SECRET-FOR-AKV>",
  "comment": "This CIFS Server Belongs to CS Department",
  "default_unix_user": "string",
  "group_policy_object_enabled": true,
  "key_vault_uri": "https://kmip-akv-keyvault.vault.azure.net/",
  "name": "CIFS1",
  "netbios": {
    "aliases": [
      "ALIAS_1",
      "ALIAS_2",
      "ALIAS_3"
    "wins_servers": [
      "10.224.65.20",
      "10.224.65.21"
  "oauth_host": "login.microsoftonline.com",
  "options": {
    "max_connections_per_session": 32,
    "max_lifs_per_session": 256,
    "max_opens_same_file_per_tree": 1000,
    "max_same_tree_connect_per_session": 5000,
    "max_same_user_sessions_per_connection": 2500,
    "max_watches_set_per_tree": 500,
    "null_user_windows_name": "string",
    "smb_credits": 128,
    "widelink_reparse_versions": [
      "smb1"
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "string",
  "proxy_username": "proxyuser",
  "security": {
    "advertised_kdc_encryptions": [
      "string"
    "restrict_anonymous": "string",
    "session_security": "string"
  "svm": {
    "name": "svm1",
  "tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
  "timeout": 25,
  "workgroup": "workgrp1"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
1115127
The cluster lacks a valid CIFS license.
3735751
Failed to authenticate and retrieve the access token from the Azure OAuth host.
3735752
Failed to extract the private key from the Azure Key Vault certificate.
3735753
Unsupported content_type in the Azure secrets response.
3735754
Failed to parse the JSON response from Azure Key Vault.
3735755
REST API call to Azure failed.
3735756
Invalid client certificate.
3735757
Failed to generate client assertion.
3735762
The provided Azure Key Vault configuration is incorrect.
3735763
The provided Azure Key Vault configuration is incomplete.
3735764
Request to Azure failed. Reason - Azure error code and Azure error message.
655388
Failed to create the CIFS server. Failure can occur due to multiple reasons. For example: STARTTLS and LDAPS cannot be used together or a password update failed or error from LDAP server or Kerberos Error: KDC has no support for encryption type.
655524
CIFS server creation failed.
655538
CIFS server creation failed because a server with the same name already exists.
655562
NetBIOS name is longer than 15 characters.
655563
NetBIOS name contains characters that are not allowed.
655771
The number of NetBIOS aliases cannot exceed the maximum supported number of '200'.
655914
Failed to create the Active Directory machine account.
655923
Retrieving credentials from AKV is not supported because the effective cluster version is not ONTAP 9.15.0 or later.
656464
Failed to create the Active Directory machine account. Reason: Invalid Credentials.
656465
Failed to create the Active Directory machine account. Reason: Account with same name already exists.
656466
Failed to create the Active Directory machine account. Reason: Domain Controller is not reachable or does not exist.
656467
Failed to create the Active Directory machine account. Reason: Organizational-Unit not found.
656473
Fields security.kdc_encryption and security.advertised_kdc_encryptions are mutually exclusive. Specify only one of the two.
655477
Only one CIFS server is supported per SVM.
656487
Missing fields when doing CIFS operation with hybrid auth user type.
string
ad_domain
default_site
string
The default site used by LIFs that do not have a site membership.
fqdn
string
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.
organizational_unit
string
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.
password
string
The account password used to add this CIFS server to the Active Directory. This is not audited.
user
string
The user account used to add this CIFS server to the Active Directory.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
cifs_netbios
aliases
array[string]
enabled
boolean
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration.
wins_servers
array[string]
admin_to_root_mapping
boolean
Specifies whether or not Administrator can be mapped to the UNIX user "root".
advanced_sparse_file
boolean
Specifies whether or not the CIFS server supports the advanced sparse file capabilities. This allows CIFS clients to query the allocated ranges of a file and to write zeroes or free data blocks for ranges of a file.
backup_symlink_enabled
boolean
Specifies whether or not to preserve UNIX symlinks during backup through SMB.
client_dup_detection_enabled
boolean
Specifies whether or not client duplicate session detection is enabled for CIFS.
client_version_reporting_enabled
boolean
Specifies whether or not client version reporting is enabled for CIFS.
copy_offload
boolean
Specifies whether or not to enable the Copy Offload feature. This feature enables direct data transfers within or between compatible storage devices without transferring the data through the host computer.
Note that this will also enable/disable the direct copy feature accordingly.
dac_enabled
boolean
Specifies whether or not the Dynamic Access Control (DAC) feature is enabled for the CIFS server.
export_policy_enabled
boolean
Specifies whether or not export policies are enabled for CIFS.
fake_open
boolean
Specifies whether or not fake open support is enabled. This parameter allows you to optimize the open and close requests coming from SMB 2 clients.
fsctl_trim
boolean
Specifies whether or not the trim requests (FSCTL_FILE_LEVEL_TRIM) are supported on the CIFS server.
junction_reparse
boolean
Specifies whether or not the reparse point support is enabled. When enabled the CIFS server exposes junction points to Windows clients as reparse points. This parameter is only active if the client has negotiated use of the SMB 2 or SMB 3 protocol. This parameter is not supported for SVMs with Infinite Volume.
large_mtu
boolean
Specifies whether or not SMB clients can send reads up to 1 MB in size.
integer
Specifies the maximum number of connections allowed per multichannel session.
integer
Specifies the maximum number of LIFs advertised per multichannel session.
integer
Specifies the maximum number of opens on the same file per tree.
integer
Specifies the maximum number of same tree connections per session.
integer
Specifies the maximum number of same user sessions per connection.
integer
Specifies the maximum number of watches set per tree.
multichannel
boolean
Specifies whether or not the CIFS server supports Multichannel.
string
Specifies a Windows User or Group name that should be mapped in case of a NULL user value.
path_component_cache
boolean
Specifies whether or not the path component cache is enabled on the CIFS server.
referral
boolean
Specifies whether or not to refer clients to more optimal LIFs. When enabled, it automatically refers clients to a data LIF local to the node which hosts the root of the requested share.
shadowcopy
boolean
Specifies whether or not to enable the Shadowcopy Feature. This feature enables to take share-based backup copies of data that is in a data-consistent state at a specific point in time where the data is accessed over SMB 3.0 shares.
shadowcopy_dir_depth
integer
Specifies the maximum level of subdirectories on which ONTAP should create shadow copies.
  • Default value: 5
  • x-nullable: true
smb_credits
integer
Specifies the maximum number of outstanding requests on a CIFS connection.
trusted_domain_enum_search_enabled
boolean
Specifies whether or not to enable trusted domain search.
  • If this parameter is set to true, it displays CIFS options only for CIFS servers that support enumeration of bidirectional trusted domains and that support searching in all bidirectional trusted domains when performing Windows user lookups for UNIX user to Windows user name mapping.
  • If set to false, it displays CIFS options for CIFS servers that do not support enumeration of bidirectional trusted domains.
array[string]
Specifies the CIFS protocol versions for which the widelink is reported as reparse point.
array[string]
boolean
Specifies whether or not an AES session key is enabled for the Netlogon channel.
boolean
Specifies whether encryption is required for domain controller connections.
kdc_encryption
boolean
Important This attribute has been deprecated. Use "security.advertised_kdc_encryptions" to specify the encryption type to use. Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
  • RC4-HMAC
  • DES
  • AES When the CIFS server is created, the domain controller creates a computer machine account in Active Directory. After a newly created machine account authenticates, the KDC and the CIFS server negotiates encryption types. At this time, the KDC becomes aware of the encryption capabilities of the particular machine account and uses those capabilities in subsequent communication with the CIFS server. In addition to negotiating encryption types during CIFS server creation, the encryption types are renegotiated when a machine account password is reset.
boolean
Specifies whether or not LDAP referral chasing is enabled for AD LDAP connections.
restrict_anonymous
string
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
  • no_restriction - No access restriction for an anonymous user.
  • no_enumeration - Enumeration is restricted for an anonymous user.
  • no_access - All access is restricted for an anonymous user.
session_security
string
Specifies client session security for AD LDAP connections. The available values are:
  • none - No Signing or Sealing.
  • sign - Sign LDAP traffic.
  • seal - Seal and Sign LDAP traffic
smb_encryption
boolean
Specifies whether encryption is required for incoming CIFS traffic.
smb_signing
boolean
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised.
boolean
Specifies whether or not channel binding is attempted in the case of TLS/LDAPS.
use_ldaps
boolean
Specifies whether or not to use use LDAPS for secure Active Directory LDAP connections by using the TLS/SSL protocols.
use_start_tls
boolean
Specifies whether or not to use SSL/TLS for allowing secure LDAP communication with Active Directory LDAP servers.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
uuid
string
cifs_service
ad_domain
ad_domain
auth-style
string
auth_user_type
string
  • x-nullable: true
string
  • client_secret
  • certificate
client_certificate
string
client_id
string
client_secret
string
comment
string
default_unix_user
string
enabled
boolean
key_vault_uri
string
name
string
netbios
cifs_netbios
oauth_host
string
options
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
security
svm
svm
tenant_id
string
timeout
integer
verify_host
boolean
workgroup
string
The workgroup name.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
