REST API reference
Creates security trace filter entries
Creates security trace filter entries to define criteria for tracing security-related events in the system. This helps in monitoring and analyzing security activities.
HTTP method and endpoint
POST /protocols/file-access-tracing/filters
Introduced in
ONTAP 9.8
  • vserver security trace filter create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
client_ip
string
Specifies the IP address from which the client accesses the file or directory.
enabled
boolean
Specifies whether to enable or disable the filter. Filters are enabled by default and are deleted after 60 mins.
index
integer
Position of the file access tracing filter.
path
string
Specifies the path for which permission tracing can be applied. The value can be complete path from root of CIFS share or root of volume for NFS.
protocol
string
Specifies the protocol for which permission trace is required.
svm
svm_reference
trace_allowed_ops
boolean
Specifies if the filter can trace file access denied and allowed events. The value of trace-allow is false by default, and it traces access denied events. The value is set to true for tracing access allowed events.
unix_user
string
Specifies the UNIX username whose access requests you want to trace. The filter would match only if the request is received with this user.
windows_user
string
Specifies the Windows username whose access requests you want to trace. The filter would match only if the request is received with this user.
Example request
  "client_ip": "10.140.68.143",
  "index": 1,
  "path": "/dir1/dir2",
  "protocol": "string",
  "svm": {
    "name": "svm1",
  "unix_user": "root",
  "windows_user": "cifs1/administrator"
Status: 201, Created
num_records
integer
Number of records
records
array[file_access_filter]
  "records": [
      "index": 1,
      "svm": {
        "name": "svm1",
Status: Default, Error
string
svm_reference
name
string
The name of the SVM.
uuid
string
file_access_filter
ONTAP allows creation of filters for file access tracing for both CIFS and NFS. These filters have protocols, path, username and client IP based on which file access operations are logged.
client_ip
string
enabled
boolean
index
integer
path
string
protocol
string
svm
svm_reference
trace_allowed_ops
boolean
unix_user
string
windows_user
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
