Creates security trace filter entries
Creates security trace filter entries to specify which network packets to monitor for diagnostic purposes. Use this endpoint when you need to track specific security events or troubleshoot network issues.
HTTP method and endpoint
POST /protocols/file-access-tracing/filters
Introduced in
ONTAP 9.8
Related ONTAP commands
vserver security trace filter create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
client_ip |
string |
Specifies the IP address from which the client accesses the file or directory. |
enabled |
boolean |
Specifies whether to enable or disable the filter. Filters are enabled by default and are deleted after 60 mins. |
index |
integer |
Position of the file access tracing filter. |
path |
string |
Specifies the path for which permission tracing can be applied. The value can be complete path from root of CIFS share or root of volume for NFS. |
protocol |
string |
Specifies the protocol for which permission trace is required. |
svm |
trace_allowed_ops |
boolean |
Specifies if the filter can trace file access denied and allowed events. The value of trace-allow is false by default, and it traces access denied events. The value is set to true for tracing access allowed events. |
unix_user |
string |
Specifies the UNIX username whose access requests you want to trace. The filter would match only if the request is received with this user. |
windows_user |
string |
Specifies the Windows username whose access requests you want to trace. The filter would match only if the request is received with this user. |
Example request
"client_ip": "10.140.68.143",
"index": "1",
"path": "/dir1/dir2",
"protocol": "string",
"svm": {
"name": "svm1",
"unix_user": "root",
"windows_user": "cifs1/administrator"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[file_access_filter] |
"records": [
"index": "1",
"svm": {
"name": "svm1",
Status: Default, Error
href |
string |
_links
svm_reference
name |
string |
The name of the SVM. |
uuid |
string |
file_access_filter
ONTAP allows creation of filters for file access tracing for both CIFS and NFS. These filters have protocols, path, username and client IP based on which file access operations are logged.
client_ip |
string |
enabled |
boolean |
index |
integer |
path |
string |
protocol |
string |
svm |
trace_allowed_ops |
boolean |
unix_user |
string |
windows_user |
string |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
