REST API reference
Create an export policy
Creates an export policy to define rules for client access to data exported by an SVM. Typically, you would use this to manage and control access permissions effectively within your network environment.
HTTP method and endpoint
POST /protocols/nfs/export-policies
Introduced in
ONTAP 9.6
Usage notes
An SVM can have any number of export policies to define rules for which clients can access data exported by the SVM. A policy with no rules prohibits access.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create an export policy.
  • name - Name of the export policy.
  • rules - Rule(s) of an export policy. Used to create the export rule and populate the export policy with export rules in a single request.
  • vserver export-policy create
  • vserver export-policy rule create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rules]
Rules of the Export Policy.
svm
svm
Example request
  "id": 0,
  "name": "string",
  "rules": [
      "anonymous_user": "string",
      "chown_mode": "string",
      "clients": [
          "match": "0.0.0.0/0"
      "index": 0,
      "ntfs_unix_security": "string",
      "protocols": [
        "string"
      "ro_rule": [
        "string"
      "rw_rule": [
        "string"
      "superuser": [
        "string"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
The number of export policy records
records
array[export_policy]
  "records": [
      "id": 0,
      "name": "string",
      "rules": [
          "clients": [
          "index": 0,
          "protocols": [
            "string"
          "ro_rule": [
            "string"
          "rw_rule": [
            "string"
          "superuser": [
            "string"
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
1703952
Invalid ruleset name provided. No spaces allowed in a ruleset name
1703954
Export policy does not exist
1704049
Invalid clientmatch: clientmatch lists require an effective cluster version of Data ONTAP 9.0 or later. Upgrade all nodes to Data ONTAP 9.0 or above to use features that operate on lists of clientmatch strings in export-policy rules
1704055
Export policies are only supported for data Vservers
3277000
Upgrade all nodes to Data ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules
3277083
User ID is not valid. Enter a value for User ID from 0 to 4294967295
string
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
allow_device_creation
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
name
string
The name of the SVM.
uuid
string
export_policy
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rules]
svm
svm
export_clients
match
string
export_clients
match
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
