REST API reference
Create an export policy
Creates an export policy to define access rules for clients interacting with data exported by an SVM. This allows you to control which clients have permission to access the SVM's exported data.
HTTP method and endpoint
POST /protocols/nfs/export-policies
Introduced in
ONTAP 9.6
Usage notes
An SVM can have any number of export policies to define rules for which clients can access data exported by the SVM. A policy with no rules prohibits access.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create an export policy.
  • name - Name of the export policy.
  • rules - Rule(s) of an export policy. Used to create the export rule and populate the export policy with export rules in a single request.
  • rules[].index - If you specify an index number that already matches a rule, the index number of the existing rule is incremented, as are the index numbers of all subsequent rules, either to the end of the list or to an open space in the list. If you do not specify an index number, the new rule is placed at the end of the policy's list.
  • vserver export-policy create
  • vserver export-policy rule create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
are_rules_truncated
boolean
Indicates whether or not export-policy rules are truncated.
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rules]
Rules of the Export Policy.
svm
svm
Example request
  "id": 0,
  "name": "string",
  "rules": [
      "anonymous_user": "string",
      "chown_mode": "string",
      "clients": [
          "match": "0.0.0.0/0"
      "ntfs_unix_security": "string",
      "protocols": [
        "string"
      "ro_rule": [
        "string"
      "rw_rule": [
        "string"
      "superuser": [
        "string"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
The number of export policy records
records
array[export_policy]
  "num_records": 1,
  "records": [
      "id": 0,
      "name": "string",
      "rules": [
          "clients": [
          "protocols": [
            "string"
          "ro_rule": [
            "string"
          "rw_rule": [
            "string"
          "superuser": [
            "string"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1703952
Invalid ruleset name provided. No spaces allowed in a ruleset name
1703954
Export policy does not exist
1704036
Invalid clientmatch: missing domain name
1704037
Invalid clientmatch: missing network name
1704038
Invalid clientmatch: missing netgroup name
1704039
Invalid clientmatch
1704040
Invalid clientmatch: address bytes masked out by netmask are non-zero
1704041
Invalid clientmatch: address bytes masked to zero by netmask
1704042
Invalid clientmatch: too many bits in netmask
1704043
Invalid clientmatch: invalid netmask
1704044
Invalid clientmatch: invalid characters in host name
1704045
Invalid clientmatch: invalid characters in domain name
1704047
The export policy name cannot be longer than 256 characters
1704049
Invalid clientmatch: clientmatch lists require an effective cluster version of Data ONTAP 9.0 or later. Upgrade all nodes to Data ONTAP 9.0 or above to use features that operate on lists of clientmatch strings in export-policy rules
1704050
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported
1704054
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-"
1704055
Export policies are only supported for data Vservers
1704064
Clientmatch host name too long
1704065
Clientmatch domain name too long
1704071
The export policy was not created because of duplicate export policy rules present in the request
2621462
The specified SVM name does not exist
2621519
SVM name is invalid. The SVM name must begin with a letter or an underscore. If the SVM is of type "sync-source", the maximum supported length is 41. Otherwise, the maximum supported length is 47
2621643
The specified SVM name is too long
2621685
SVM name length cannot be zero
2621706
The specified SVM UUID is incorrect for the specified SVM name
3277000
Upgrade all nodes to ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules
3277083
User ID is not valid. Enter a value for User ID from 0 to 4294967295
3277149
The "Anon" field cannot be an empty string
3277249
Setting "allow-cache-async-writes" to "true" in export-policy rules requires an effective cluster version of 9.19.1 or later.
6691623
User is not authorized
string
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
allow_device_creation
boolean
Specifies whether or not device creation is allowed.
allow_nfs_tls_only
boolean
Specifies whether to allow NFS access only over TLS connections.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
name
string
uuid
string
export_policy
are_rules_truncated
boolean
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rules]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
