Create a portset
Creates a portset to group network interfaces under a single name for streamlined management. This is useful when organizing interfaces by protocol or other criteria for SAN configurations.
HTTP method and endpoint
POST /protocols/san/portsets
Introduced in
ONTAP 9.9
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the portset. -
name- Name of the portset.
Recommended optional properties
protocol- The network protocol of the interfaces in the portset. -
interfaces- Network interfaces to include in the portset. This property can be used to create the portset and populate it with network interfaces in a single request.
Default property values
If not specified in POST, the following default property values are assigned.
protocol- mixed - Data protocol of the portset's network interfaces.
Related ONTAP commands
lun portset create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
igroups |
array[igroups] |
An array initiator groups to which the portset is bound. |
interfaces |
array[interfaces] |
An array of network interfaces that are members of the portset. These are the only network interfaces through which the initiators of a bound igroup can access mapped LUNs. Zero or more network interfaces can be supplied when the portset is created. After creation, network interfaces can be added or removed from the portset using the |
name |
string |
The name of the portset. Required in POST. The name of a portset cannot be changed after creation. |
protocol |
string |
The protocols supported by the portset. This restricts the type of network interfaces that can be added to the portset. Optional in POST; if not supplied, this defaults to mixed. The protocol of a portset cannot be changed after creation. |
svm |
uuid |
string |
The unique identifier for a portset. |
Example request
"igroups": [
"name": "igroup1",
"interfaces": [
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"name": "lif1",
"name": "portset1",
"protocol": "string",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[portset] |
"records": [
"igroups": [
"name": "igroup1",
"interfaces": [
"fc": {
"name": "fc_lif1",
"ip": {
"name": "lif1",
"name": "portset1",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1254259 |
A portset with the same name already exists in the SVM. |
2621462 |
The specified SVM does not exist. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5373958 |
The specified portset name contains invalid characters. |
5374905 |
An invalid interfaces array element was specified. |
5374906 |
A specified network interface was not found. |
5374907 |
The specified network interface UUID and name don't identify the same network interface. |
5374914 |
An attempt was made to add a network interface of an incompatible protocol to a portset. |
href |
string |
_links
igroups
name |
string |
The name of the initiator group. |
uuid |
string |
The unique identifier of the initiator group. |
fc
An FC interface.
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
ip
A network interface. Either UUID or name may be supplied on input.
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
interfaces
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
uuid |
string |
The unique identifier of the network interface. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
portset
igroups |
array[igroups] |
interfaces |
array[interfaces] |
name |
string |
protocol |
string |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
