REST API reference
Create a portset
POST /protocols/san/portsets
Introduced In: 9.9
Creates a portset.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the portset.
  • name - Name of the portset.
  • protocol - The network protocol of the interfaces in the portset.
  • interfaces - Network interfaces to include in the portset. This property can be used to create the portset and populate it with network interfaces in a single request.
Default property values
If not specified in POST, the following default property values are assigned.
  • protocol - mixed - Data protocol of the portset's network interfaces.
  • lun portset create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
igroups
array[igroups]
An array initiator groups to which the portset is bound.
interfaces
array[interfaces]
An array of network interfaces that are members of the portset. These are the only network interfaces through which the initiators of a bound igroup can access mapped LUNs.
Zero or more network interfaces can be supplied when the portset is created. After creation, network interfaces can be added or removed from the portset using the /protocols/san/portsets/{portset.uuid}/interfaces endpoint. See link:post-protocols-san-portsets-interfaces_-san-portset-interface-create_anddelete-protocols-san-portsets-interfaces-.htmlPOST /protocols/san/portsets/{portset.uuid}/interfaces and [DELETE /protocols/san/portsets/{portset.uuid}/interfaces/{uuid}] for more details.
name
string
The name of the portset. Required in POST.
The name of a portset cannot be changed after creation.
protocol
string
The protocols supported by the portset. This restricts the type of network interfaces that can be added to the portset. Optional in POST; if not supplied, this defaults to mixed.
The protocol of a portset cannot be changed after creation.
svm
svm
uuid
string
The unique identifier for a portset.
Example request
  "igroups": [
      "name": "igroup1",
  "interfaces": [
      "fc": {
        "name": "fc_lif1",
        "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
        "wwpn": "20:00:00:50:56:b4:13:a8"
      "ip": {
        "name": "lif1",
  "name": "portset1",
  "protocol": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[portset]
  "num_records": 1,
  "records": [
      "igroups": [
          "name": "igroup1",
      "interfaces": [
          "fc": {
            "name": "fc_lif1",
          "ip": {
            "name": "lif1",
      "name": "portset1",
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1254259
A portset with the same name already exists in the SVM.
2621462
The specified SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5373958
The specified portset name contains invalid characters.
5373982
An invalid WWN was specified. The length is incorrect.
5373983
An invalid WWN was specified. The format is incorrect.
5374905
An invalid interfaces array element was specified.
5374906
A specified network interface was not found.
5374907
The specified network interface UUID and name don't identify the same network interface.
5374914
An attempt was made to add a network interface of an incompatible protocol to a portset.
string
igroups
name
string
The name of the initiator group.
uuid
string
The unique identifier of the initiator group.
fc
An FC interface.
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
ip
A network interface. Either UUID or name may be supplied on input.
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
interfaces
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
fc
fc
An FC interface.
ip
ip
uuid
string
The unique identifier of the network interface.
svm
name
string
uuid
string
portset
igroups
array[igroups]
interfaces
array[interfaces]
name
string
protocol
string
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
