REST API reference
Add portset network interfaces
Adds network interfaces to a portset, enabling streamlined management of interface associations within a storage area network.
HTTP method and endpoint
POST /protocols/san/portsets/{portset.uuid}/interfaces
Introduced in
ONTAP 9.9
Usage notes
Adds one or more interfaces to a portset.
Required properties
  • fc, ip or records - Network interface(s) to add to the portset.
  • lun portset add
portset.uuid
string
path
True
The unique identifier of the portset.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
fc
fc
An FC interface.
ip
ip
A network interface. Either UUID or name may be supplied on input.
portset
portset
The portset in which the network interface is found.
Note that this does not mean that the network interface cannot also be found in other portsets.
records
array[records]
An array of network interfaces specified to add multiple interfaces to a portset in a single API call. Valid in POST only and not allowed when the fc or ip property is used.
uuid
string
The unique identifier of the network interface.
Example request
  "fc": {
    "name": "fc_lif1",
    "uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
    "wwpn": "20:00:00:50:56:b4:13:a8"
  "ip": {
    "name": "lif1",
  "portset": {
  "records": [
      "fc": {
        "name": "fc_lif1",
      "ip": {
        "name": "lif1",
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[portset_interface]
  "num_records": 1,
  "records": [
      "fc": {
        "name": "fc_lif1",
      "ip": {
        "name": "lif1",
      "portset": {
      "records": [
          "fc": {
            "name": "fc_lif1",
          "ip": {
            "name": "lif1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5374906
A specified network interface was not found.
5374907
The specified network interface UUID and name don't identify the same network interface.
5374909
An invalid combination of network interface properties was specified.
5374910
An incomplete set of network interface properties was specified.
5374914
An attempt was made to add a network interface of an incompatible protocol to a portset.
5374915
An attempt was made to add a duplicate network interface to a portset.
string
fc
An FC interface.
name
string
The name of the FC interface.
uuid
string
The unique identifier of the FC interface.
wwpn
string
The WWPN of the FC interface.
ip
IP information
ip
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
portset
uuid
string
records
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
fc
fc
An FC interface.
ip
ip
uuid
string
portset_interface
fc
fc
An FC interface.
ip
ip
portset
portset
records
array[records]
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
