Add portset network interfaces
Adds network interfaces to a portset, enabling streamlined management of interface associations within a storage area network.
HTTP method and endpoint
POST /protocols/san/portsets/{portset.uuid}/interfaces
Introduced in
ONTAP 9.9
Usage notes
Adds one or more interfaces to a portset.
Required properties
fc,iporrecords- Network interface(s) to add to the portset.
Related ONTAP commands
lun portset add
Learn more
portset.uuid |
string |
path |
True |
The unique identifier of the portset. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
fc |
An FC interface. |
ip |
A network interface. Either UUID or name may be supplied on input. |
portset |
The portset in which the network interface is found. Note that this does not mean that the network interface cannot also be found in other portsets. |
records |
array[records] |
An array of network interfaces specified to add multiple interfaces to a portset in a single API call. Valid in POST only and not allowed when the |
uuid |
string |
The unique identifier of the network interface. |
Example request
"fc": {
"name": "fc_lif1",
"uuid": "3a09ab42-4da1-32cf-9d35-3385a6101a0b",
"wwpn": "20:00:00:50:56:b4:13:a8"
"ip": {
"name": "lif1",
"portset": {
"records": [
"fc": {
"name": "fc_lif1",
"ip": {
"name": "lif1",
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[portset_interface] |
"num_records": 1,
"records": [
"fc": {
"name": "fc_lif1",
"ip": {
"name": "lif1",
"portset": {
"records": [
"fc": {
"name": "fc_lif1",
"ip": {
"name": "lif1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374906 |
A specified network interface was not found. |
5374907 |
The specified network interface UUID and name don't identify the same network interface. |
5374909 |
An invalid combination of network interface properties was specified. |
5374910 |
An incomplete set of network interface properties was specified. |
5374914 |
An attempt was made to add a network interface of an incompatible protocol to a portset. |
5374915 |
An attempt was made to add a duplicate network interface to a portset. |
href |
string |
_links
fc
An FC interface.
name |
string |
The name of the FC interface. |
uuid |
string |
The unique identifier of the FC interface. |
wwpn |
string |
The WWPN of the FC interface. |
ip
IP information
ip
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
portset
uuid |
string |
records
A container for either a Fibre Channel network interface or an IP network interface. On POST fc and ip are mutually exclusive.
fc |
An FC interface. |
ip |
uuid |
string |
portset_interface
fc |
An FC interface. |
ip |
portset |
records |
array[records] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
