Define remote syslog or splunk server information
Configures remote syslog or Splunk server information to manage the logging and monitoring of system events. Use this capability to ensure effective tracking and analysis of your system's activities.
HTTP method and endpoint
POST /security/audit/destinations
Introduced in
ONTAP 9.6
Usage notes
Configures remote syslog/splunk server information.
Required properties
All of the following fields are required for creating a remote syslog/splunk destination
address
Optional properties
All of the following fields are optional for creating a remote syslog/splunk destination
port -
protocol -
facility -
verify_server(Can only be "true" when protocol is "tcp_encrypted")
force |
boolean |
query |
False |
Skip the Connectivity Test
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname. |
facility |
string |
This is the standard Syslog Facility value that is used when sending audit records to a remote server. |
port |
integer |
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514. |
protocol |
string |
Log forwarding protocol |
verify_server |
boolean |
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate. |
Example request
"address": "string",
"facility": "string",
"protocol": "string"
Status: 202, Accepted
num_records |
integer |
Number of records |
records |
array[security_audit_log_forward] |
"records": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
15661 |
The object specified could not be found |
13114 |
Internal error |
13115 |
Invalid input |
4522285 |
Server verification cannot be enabled because it requires a protocol with encryption. Encryption can be selected using the protocol field. |
9240603 |
Cannot ping destination host. Verify connectivity to desired host or skip the connectivity check with the -force parameter. |
327698 |
Failed to create RPC client to destination host |
9240609 |
Cannot connect to destination host. |
9240604 |
Cannot resolve the destination host. |
address |
string |
facility |
string |
port |
integer |
protocol |
string |
verify_server |
boolean |
href |
string |
_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
