REST API reference
Define remote syslog or splunk server information
Configures remote syslog or Splunk server information to define how logging data is directed to these external destinations. This setup is essential for integrating external logging systems with your ONTAP environment.
HTTP method and endpoint
POST /security/audit/destinations
Introduced in
ONTAP 9.6
Usage notes
Configures remote syslog/splunk server information.
Required properties
All of the following fields are required for creating a remote syslog/splunk destination
  • address
Optional properties
All of the following fields are optional for creating a remote syslog/splunk destination
  • port
  • ipspace
  • protocol
  • facility
  • verify_server (Can only be "true" when protocol is "tcp_encrypted")
force
boolean
query
False
Skip the Connectivity Test
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
address
string
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname.
facility
string
This is the standard Syslog Facility value that is used when sending audit records to a remote server.
ipspace
ipspace
port
integer
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514.
protocol
string
Log forwarding protocol
verify_server
boolean
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate.
Example request
  "address": "string",
  "facility": "string",
  "ipspace": {
    "name": "exchange",
  "protocol": "string"
Status: 202, Accepted
num_records
integer
Number of records
records
array[security_audit_log_forward]
  "num_records": 1,
  "records": [
      "ipspace": {
        "name": "exchange",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
15661
The object specified could not be found
13114
Internal error
13115
Invalid input
4522285
Server verification cannot be enabled because it requires a protocol with encryption. Encryption can be selected using the protocol field.
9240603
Cannot ping destination host. Verify connectivity to desired host or skip the connectivity check with the -force parameter.
327698
Failed to create RPC client to destination host
9240609
Cannot connect to destination host.
9240604
Cannot resolve the destination host.
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
address
string
facility
string
ipspace
ipspace
port
integer
protocol
string
verify_server
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
