Create the NIS configuration for the cluster
Configures the NIS server for the cluster by specifying the NIS domain and servers. Use this endpoint when setting up or modifying the network information service configuration for your environment.
HTTP method and endpoint
POST /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
The cluster can have one NIS server configuration. Specify the NIS domain and NIS servers as input. Domain name and servers fields cannot be empty.
Both FQDNs and IP addresses are supported for the server property. IPv6 must be enabled if IPv6 family addresses are specified in the server property. A maximum of ten NIS servers are supported.
Required properties
domain- NIS domain to which this configuration belongs. -
servers- List of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
Request Body
| Name | Type | Description |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
Example request
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
Status: 201, Created
num_records |
integer |
Number of NIS domain records. |
records |
array[cluster_nis_service] |
"records": [
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966253 |
IPv6 is not enabled in the cluster. |
3276964 |
The NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters. |
3276933 |
A maximum of 10 NIS servers can be configured per SVM. |
13434916 |
The SVM is in the process of being created. Wait a few minutes, and then try the command again. |
23724109 |
DNS resolution failed for one or more specified servers. |
23724112 |
DNS resolution failed due to an internal error. Contact technical support if this issue persists. |
23724132 |
DNS resolution failed for all the specified servers. |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 interfaces. |
href |
string |
_links
cluster_nis_service
bound_servers |
array[string] |
domain |
string |
servers |
array[string] |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
