REST API reference
Create the NIS configuration for the cluster
Creates the NIS configuration for the cluster to specify the NIS domain and servers. Use this endpoint to set up or update the network information service parameters for your cluster environment.
HTTP method and endpoint
POST /security/authentication/cluster/nis
Introduced in
ONTAP 9.6
Usage notes
The cluster can have one NIS server configuration. Specify the NIS domain and NIS servers as input. Domain name and servers fields cannot be empty. Both FQDNs and IP addresses are supported for the server property. IPv6 must be enabled if IPv6 family addresses are specified in the server property. A maximum of ten NIS servers are supported.
Required properties
  • domain - NIS domain to which this configuration belongs.
  • servers - List of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
Request Body
Name Type Description
_links
_links
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
Example request
  "bound_servers": [
    "string"
  "domain": "string",
  "servers": [
    "string"
Status: 201, Created
num_records
integer
Number of NIS domain records.
records
array[cluster_nis_service]
  "num_records": 1,
  "records": [
      "bound_servers": [
        "string"
      "domain": "string",
      "servers": [
        "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1966253
IPv6 is not enabled in the cluster.
3276964
The NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters.
3276933
A maximum of 10 NIS servers can be configured per SVM.
13434916
The SVM is in the process of being created. Wait a few minutes, and then try the command again.
23724109
DNS resolution failed for one or more specified servers.
23724112
DNS resolution failed due to an internal error. Contact technical support if this issue persists.
23724132
DNS resolution failed for all the specified servers.
23724130
Cannot use an IPv6 name server address because there are no IPv6 interfaces.
string
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
cluster_nis_service
_links
_links
bound_servers
array[string]
domain
string
servers
array[string]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
