Create a SAML service provider configuration
Creates a SAML service provider configuration to establish a trusted connection for identity management and authentication with an Identity Provider (IdP). This setup is essential for integrating SAML authentication into your system.
HTTP method and endpoint
POST /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Usage notes
Note that "common_name" is mutually exclusive with "serial_number" and "ca" in POST. SAML will initially be disabled, requiring a patch to set "enabled" to "true", so that the user has time to complete the setup of the IdP.
Required properties
idp_uri
Optional properties
certificate -
enabled -
host
verify_metadata_server |
boolean |
query |
False |
Verify IdP metadata server identity.
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
certificate |
host |
string |
The SAML service provider host. |
idp_uri |
string |
The identity provider (IdP) metadata location. Required for POST operations. |
Example request
"certificate": {
"ca": "string",
"common_name": "cluster1",
"serial_number": "1506B24A94F566BA"
"enabled": null,
"host": "string",
"idp_uri": "https://idp.example.com/FederationMetadata/2007-06/FederationMetadata.xml"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320789 |
Failed to download data file from specified URI. |
12320794 |
The host parameter provided must be the cluster management interface's IP address. If the cluster management interface is not available, the node management interface's IP address must be used. |
12320795 |
A valid cluster or node management interface IP address must be provided. |
12320805 |
The certificate information provided does not match any installed certificates. |
12320806 |
The certificate information entered does not match any installed certificates. |
12320814 |
An invalid IDP URI has been entered. |
12320815 |
An IDP URI must be an HTTPS or FTPS URI. |
href |
string |
_links
certificate
ca |
string |
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name. |
common_name |
string |
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number. |
serial_number |
string |
Server certificate serial number. This cannot be used with the server certificate common name. |
security_saml_sp
certificate |
host |
string |
idp_uri |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
