REST API reference
Create an SAML service provider configuration
Configures a SAML service provider, establishing the necessary settings for identity provider integration. You might use this endpoint when preparing the environment for secure authentication and completing the setup process.
HTTP method and endpoint
POST /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Usage notes
Creates a SAML service provider configuration. Note that "common_name" is mutually exclusive with "serial_number" and "ca" in POST. SAML will initially be disabled, requiring a patch to set "enabled" to "true", so that the user has time to complete the setup of the IdP.
Required properties
  • idp_uri
Optional properties
  • certificate
  • enabled
  • host
verify_metadata_server
boolean
query
False
Verify IdP metadata server identity.
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
certificate
certificate
host
string
The SAML service provider host.
idp_uri
string
The identity provider (IdP) metadata location. Required for POST operations.
Example request
  "certificate": {
    "ca": "string",
    "common_name": "cluster1",
    "serial_number": "1506B24A94F566BA"
  "enabled": true,
  "host": "string",
  "idp_uri": "https://idp.example.com/FederationMetadata/2007-06/FederationMetadata.xml"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
12320789
Failed to download data file from specified URI.
12320794
The host parameter provided must be the cluster management interface's IP address. If the cluster management interface is not available, the node management interface's IP address must be used.
12320795
A valid cluster or node management interface IP address must be provided.
12320805
The certificate information provided does not match any installed certificates.
12320806
The certificate information entered does not match any installed certificates.
12320814
An invalid IDP URI has been entered.
12320815
An IDP URI must be an HTTPS or FTPS URI.
12320819
Use the HTTPS scheme for the idp_uri or set verify_metadata_server to false.
12320820
No certificate is installed with the specified certificate.ca and certificate.serial.
12320821
No certificate is installed with the specified certificate.common_name.
12320823
string
certificate
ca
string
Server certificate issuing certificate authority (CA). This cannot be used with the server certificate common name.
common_name
string
Server certificate common name. This cannot be used with the certificate authority (CA) or serial_number.
serial_number
string
Server certificate serial number. This cannot be used with the server certificate common name.
security_saml_sp
certificate
certificate
host
string
idp_uri
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
