REST API reference
Start a SnapMirror transfer operation
Initiates a SnapMirror transfer operation, which can be used to perform restore, initialize, or update actions depending on the SnapMirror relationship type and current state. This allows you to manage data replication across your storage systems efficiently.
HTTP method and endpoint
POST /snapmirror/relationships/{relationship.uuid}/transfers
Introduced in
ONTAP 9.6
Usage notes
Starts a SnapMirror transfer operation. This API initiates a restore operation if the SnapMirror relationship is of type "restore". Otherwise, it intiates a SnapMirror "initialize" operation or "update" operation based on the current SnapMirror state.
Default property values
  • storage_efficiency_enabled - true
  • snapmirror update
  • snapmirror initialize
  • snapmirror restore
The following examples show how to perform SnapMirror "initialize", "update", and "restore" operations.
Perform SnapMirror initialize or update
 POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{}'
Perform SnapMirror initialize, update or restore with throttle value set
 POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{"throttle":"100"}'
Perform SnapMirror restore transfer of a file
 POST "/api/snapmirror/relationships/c8c62a90-0fef-11e9-b09e-0050568e7067/transfers" '{"source_snapshot": "src", "files":[{"source_path": "/a1.txt.0", "destination_path": "/a1-renamed.txt.0"}]}'
relationship.uuid
string
path
True
Relationship UUID
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
Amount of data transferred in bytes as recorded in the restart checkpoint.
end_time
string
End time of the transfer.
error_info
error_info
Error information for the transfer.
files
array[files]
This is supported for transfer of restore relationship only. This specifies the list of files or LUNs to be restored. Can contain up to eight files or LUNs.
relationship
relationship
snapshot
string
Name of Snapshot copy being transferred.
source_snapshot
string
Specifies the Snapshot copy on the source to be transferred to the destination.
boolean
This is supported for transfer of restore relationship only. Set this property to "false" to turn off storage efficiency for data transferred over the wire and written to the destination.
throttle
integer
Throttle in KB/s. Defaults to throttle setting of the associated SnapMirror policy if set, or 0, which is interpreted as unlimited.
total_duration
string
Elapsed transfer time.
uuid
string
Example request
  "bytes_transferred": 0,
  "checkpoint_size": 0,
  "end_time": "2020-12-02T18:36:19-08:00",
  "error_info": {
    "code": 6620046,
    "message": "Transfer aborted"
  "files": [
      "destination_path": "/dirb/file2",
      "source_path": "/dira/file1"
  "relationship": {
    "destination": {
      "cluster": {
        "name": "cluster1",
      "consistency_group_volumes": [
          "name": "volume1",
      "ipspace": "Default",
      "path": "svm1:volume1",
      "svm": {
        "name": "svm1",
    "uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
  "snapshot": "string",
  "source_snapshot": "string",
  "throttle": 0,
  "total_duration": "PT28M41S",
Status: 201, Created
Status: Default
ONTAP Error Response codes
Error code Description
13303845
Restore operation failed
13303812
Initialize operation failed
13303844
Update operation failed
13303846
Empty source path file list
13303847
Invalid arguments
13304040
Throttle not supported for update of Synchronous SnapMirror relationships
6620237
SnapMirror relationship database write failed
6620238
SnapMirror relationship database read failed
string
error_info
code
integer
Error code
message
string
Error message
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path
string
source_path
string
cluster
name
string
uuid
string
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.8
svm
name
string
The name of the SVM.
uuid
string
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster
cluster
array[consistency_group_volumes]
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group.
ipspace
string
Optional property to specify the IPSpace of the SVM.
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
  • example: svm1:volume1
  • Introduced in: 9.6
svm
svm
relationship
destination
snapmirror_endpoint
restore
boolean
Is the relationship for restore?
uuid
string
snapmirror_transfer
SnapMirror transfer information
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
end_time
string
error_info
error_info
files
array[files]
relationship
relationship
snapshot
string
source_snapshot
string
boolean
throttle
integer
total_duration
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
