Start a SnapMirror transfer operation
Initiates a SnapMirror transfer operation to either restore data or synchronize SnapMirror relationships based on their current state. Use this to manage data replication and recovery tasks efficiently.
HTTP method and endpoint
POST /snapmirror/relationships/{relationship.uuid}/transfers
Introduced in
ONTAP 9.6
Usage notes
Starts a SnapMirror transfer operation. This API initiates a restore operation if the SnapMirror relationship is of type "restore". Otherwise, it intiates a SnapMirror "initialize" operation or "update" operation based on the current SnapMirror state.
Default property values
storage_efficiency_enabled- true
Related ONTAP commands
snapmirror update -
snapmirror initialize -
snapmirror restore
The following examples show how to perform SnapMirror "initialize", "update", and "restore" operations.
Perform SnapMirror initialize or update
POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{}'
Perform SnapMirror initialize, update or restore with throttle value set
POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{"throttle":"100"}'
Perform SnapMirror restore transfer of a file
POST "/api/snapmirror/relationships/c8c62a90-0fef-11e9-b09e-0050568e7067/transfers" '{"source_snapshot": "src", "files":[{"source_path": "/a1.txt.0", "destination_path": "/a1-renamed.txt.0"}]}'
Performing a SnapMirror initialize or update using a particular Snapshot copy.
POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{"source_snapshot":"snap1"}'
relationship.uuid |
string |
path |
True |
Relationship UUID |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
Amount of data transferred in bytes as recorded in the restart checkpoint. |
end_time |
string |
End time of the transfer. |
error_info |
Error information for the transfer. |
files |
array[files] |
This is supported for transfer of restore relationship only. This specifies the list of files or LUNs to be restored. Can contain up to eight files or LUNs. |
relationship |
snapshot |
string |
Name of Snapshot copy being transferred. |
source_snapshot |
string |
Specifies the Snapshot copy on the source to be transferred to the destination. |
storage_efficiency_enabled |
boolean |
This is supported for transfer of restore relationship only. Set this property to "false" to turn off storage efficiency for data transferred over the wire and written to the destination. |
throttle |
integer |
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship or SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited. |
total_duration |
string |
Elapsed transfer time. |
uuid |
string |
Example request
"bytes_transferred": 0,
"checkpoint_size": 0,
"end_time": "2020-12-02T18:36:19-08:00",
"error_info": {
"code": 6620046,
"message": "Transfer aborted"
"files": [
"destination_path": "/dirb/file2",
"source_path": "/dira/file1"
"relationship": {
"destination": {
"cluster": {
"name": "cluster1",
"consistency_group_volumes": [
"name": "volume1",
"ipspace": "Default",
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
"snapshot": "string",
"source_snapshot": "string",
"throttle": 0,
"total_duration": "PT28M41S",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303845 |
Restore operation failed |
13303812 |
Initialize operation failed |
13303844 |
Update operation failed |
13303846 |
Empty source path file list |
13303847 |
Invalid arguments |
13304040 |
Throttle not supported for update of Synchronous SnapMirror relationships |
6620237 |
SnapMirror relationship database write failed |
6620238 |
SnapMirror relationship database read failed |
href |
string |
_links
error_info
code |
integer |
Error code |
message |
string |
Error message |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path |
string |
source_path |
string |
cluster
name |
string |
uuid |
string |
name |
string |
The name of the volume. |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster |
consistency_group_volumes |
array[consistency_group_volumes] |
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group. |
ipspace |
string |
Optional property to specify the IPSpace of the SVM. |
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
svm |
relationship
destination |
restore |
boolean |
Is the relationship for restore? |
uuid |
string |
snapmirror_transfer
SnapMirror transfer information
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
end_time |
string |
error_info |
files |
array[files] |
relationship |
snapshot |
string |
source_snapshot |
string |
boolean |
throttle |
integer |
total_duration |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
