REST API reference
Manage SnapMirror relationship tranfers
Manage transfers within your SnapMirror relationships using this API. Execute operations like "initialize", "update", "restore-transfer", and "abort" for asynchronous relationships, while synchronous relationships support the "initialize" operation. Monitor the status of active and recently terminated transfers efficiently.
Overview
This API is used to manage transfers on an existing SnapMirror relationship.
You can initiate SnapMirror operations such as "initialize", "update", "restore-transfer", and "abort" using this API on asynchronous SnapMirror relationship. On a synchronous SnapMirror relationship, you can initiate SnapMirror "initialize" operation. The GET for this API reports the status of both active transfers and transfers that have terminated within the past 24 hours. For the restore relationships, the POST on transfers API triggers "restore-transfer". Successful completion of "restore" also deletes the restore relationship. If the "restore" fails, DELETE on relationships must be called to delete the restore relationship.
