Manage SnapMirror relationship tranfers
Manage transfers on SnapMirror relationships to coordinate data replication processes. Use this API to initiate operations like "initialize", "update", and "restore-transfer" on asynchronous relationships, while synchronous relationships support "initialize". Check transfer statuses with GET requests, and manage restore relationships post-transfer completion.
Overview
This API is used to manage transfers on an existing SnapMirror relationship.
You can initiate SnapMirror operations such as "initialize", "update", "restore-transfer", and "abort" using this API on asynchronous SnapMirror relationship. On a synchronous SnapMirror relationship, you can initiate SnapMirror "initialize" operation. The GET for this API reports the status of both active transfers and transfers that have terminated within the past 24 hours. For the restore relationships, the POST on transfers API triggers "restore-transfer". Successful completion of "restore" also deletes the restore relationship. If the "restore" fails, DELETE on relationships must be called to delete the restore relationship.
