Manage SnapMirror relationship tranfers
Manage SnapMirror relationship transfers by initiating operations such as "initialize", "update", "restore-transfer", and "abort" on asynchronous relationships. For synchronous SnapMirror relationships, initiate "initialize" operations to maintain data synchronization. Use this API to monitor active and recently terminated transfers, ensuring efficient data replication and recovery.
Overview
This API is used to manage transfers on an existing SnapMirror relationship.
You can initiate SnapMirror operations such as "initialize", "update", "restore-transfer", and "abort" using this API on asynchronous SnapMirror relationship. On a synchronous SnapMirror relationship, you can initiate SnapMirror "initialize" operation. The GET for this API reports the status of both active transfers and transfers that have terminated within the past 24 hours. For the restore relationships, the POST on transfers API triggers "restore-transfer". Successful completion of "restore" also deletes the restore relationship. If the "restore" fails, DELETE on relationships must be called to delete the restore relationship.
A transfer on an asynchronous SnapMirror relationship with Application Consistency Group endpoints expands the destination Application Consistency Group endpoint if the source Application Consistency Group endpoint is already expanded.
