REST API reference
Start a SnapMirror transfer operation
POST /snapmirror/relationships/{relationship.uuid}/transfers
Introduced In: 9.6
Starts a SnapMirror transfer operation. This API initiates a restore operation if the SnapMirror relationship is of type "restore". Otherwise, it initiates a SnapMirror "initialize" operation or "update" operation based on the current SnapMirror state.
Default property values
  • storage_efficiency_enabled - true
  • snapmirror update
  • snapmirror initialize
  • snapmirror restore
The following examples show how to perform SnapMirror "initialize", "update", and "restore" operations.
Perform SnapMirror initialize or update
 POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{}'
Perform SnapMirror initialize, update or restore with throttle value set
 POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{"throttle":"100"}'
Perform SnapMirror restore transfer of a file
 POST "/api/snapmirror/relationships/c8c62a90-0fef-11e9-b09e-0050568e7067/transfers" '{"source_snapshot": "src", "files":[{"source_path": "/a1.txt.0", "destination_path": "/a1-renamed.txt.0"}]}'
Performing a SnapMirror initialize or update using a particular snapshot.
 POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{"source_snapshot":"snap1"}'
relationship.uuid
string
path
True
SnapMirror relationship UUID
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
Amount of data transferred in bytes as recorded in the restart checkpoint.
end_time
string
End time of the transfer.
error_info
error_info
Error information for the transfer.
files
array[files]
This is supported for transfer of restore relationship only. This specifies the list of files or LUNs to be restored. Can contain up to eight files or LUNs.
last_updated_time
string
Last updated time of the bytes transferred in an active transfer.
network_compression_ratio
string
Specifies the compression ratio achieved for the data sent over the wire with network compression enabled. This property is only valid for active transfers.
on_demand_attrs
string
Specifies whether or not an on-demand restore is being carried out. This is only supported for the transfer of restore relationships for entire volumes from the object store. A value for read_write_with_user_data_pull should be provided to start an on-demand restore. A file restore from the object store does not support this option.
options
array[options]
Options for snapmirror transfer.
relationship
relationship
snapshot
string
Name of snapshot being transferred.
source_snapshot
string
Specifies the snapshot on the source to be transferred to the destination.
boolean
This is supported for transfer of restore relationship only. Set this property to "false" to turn off storage efficiency for data transferred over the wire and written to the destination.
throttle
integer
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship or SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.
total_duration
string
Elapsed transfer time.
uuid
string
Unique identifier of the SnapMirror transfer.
Example request
  "bytes_transferred": 0,
  "checkpoint_size": 0,
  "end_time": "2020-12-02 18:36:19 -0800",
  "error_info": {
    "code": 6620046,
    "message": "Transfer aborted"
  "files": [
      "destination_path": "/dirb/file2",
      "source_path": "/dira/file1"
  "last_updated_time": "2023-09-15 16:58:39 -0700",
  "network_compression_ratio": 61,
  "on_demand_attrs": "read_write_with_user_data_pull",
  "options": [
  "relationship": {
    "destination": {
      "cluster": {
        "name": "cluster1",
      "consistency_group_volumes": [
          "name": "volume1",
      "ipspace": "Default",
      "luns": {
        "name": "/vol/volume1/lun1",
      "path": "svm1:volume1",
      "svm": {
        "name": "svm1",
    "uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
  "snapshot": "string",
  "source_snapshot": "string",
  "throttle": 0,
  "total_duration": "PT28M41S",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response codes
Error code Description
13303845
Restore operation failed
13303812
Initialize operation failed
13303844
Update operation failed
13303846
Empty source path file list
13303847
Invalid property
13304040
Throttle not supported for update of Synchronous SnapMirror relationships
6620237
SnapMirror relationship database write failed
6620238
SnapMirror relationship database read failed
| 13304134 | The overwrite property specified does not match the value specified in the previous request. || | 6619720 | Relationship information has been updated and is being propagated. Wait a few minutes and try the operation again. | | 13303816 | Could not retrieve the state or status values for the relationship. Wait a few minutes and try the operation again. | | 13304159 | Could not retrieve the state or status values for the relationship. Wait a few minutes and try the operation again. If the error persists, address the error condition shown. |
string
error_info
code
integer
Error code
message
string
Error message
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path
string
source_path
string
options
cluster
name
string
uuid
string
name
string
The name of the volume.
uuid
string
Unique identifier of the volume. This corresponds to the instance-uuid that is exposed in the CLI and ONTAPI. It does not change due to a volume move.
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • x-ntap-createOnly: true
  • Introduced in: 9.8
  • x-nullable: true
luns
Optional property for a SnapMirror endpoint. Specifies the list of source LUNs and optionally list of destination LUNs during SnapMirror Consistency Group LUN restore operation.
name
string
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the LUN.
svm
name
string
uuid
string
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster
cluster
array[consistency_group_volumes]
This property specifies the list of FlexVol volumes or LUNs of a Consistency Group. Optional on the ASA r2 platform. Mandatory for all other platforms.
ipspace
string
Optional property to specify the IPSpace of the SVM.
luns
luns
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
  • example: svm1:volume1
  • Introduced in: 9.6
  • x-nullable: true
svm
svm
relationship
destination
snapmirror_endpoint
restore
boolean
Is the relationship for restore?
uuid
string
Unique identifier of the SnapMirror relationship.
snapmirror_transfer
SnapMirror transfer information
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
end_time
string
error_info
error_info
files
array[files]
last_updated_time
string
string
on_demand_attrs
string
options
array[options]
relationship
relationship
snapshot
string
source_snapshot
string
boolean
throttle
integer
total_duration
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
