REST API reference
Start a file copy operation
Initiates a file copy operation on flexible volumes, transferring specified files to designated destinations. Use this when you need to duplicate files within your storage system.
HTTP method and endpoint
POST /storage/file/copy
Introduced in
ONTAP 9.8
Usage notes
Starts a file copy operation. Only supported on flexible volumes.
Required properties
  • files_to_copy - List of files with the destination they are to be copied to.
Default property values
  • cutover_time - 10
  • hold_quiescence - false
  • max_throughput - 0
  • reference_cutover_time - 10
  • volume file copy start
Copying two files
The POST request is used to copy file(s).
# The API:
/api/storage/file/copy
# The call:
curl -X POST  "https://<mgmt-ip>/api/storage/file/copy" -H "accept: application/hal+json" -d '{"files_to_copy":[{"source":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/src_f1"},"destination":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/dst_f1"}}, {"source":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/src_f2"},"destination":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/dst_f2"}}]}'
# The response:
"job": {
  "uuid": "b89bc5dd-94a3-11e8-a7a3-0050568edf84",
       "href": "/api/cluster/jobs/b89bc5dd-94a3-11e8-a7a3-0050568edf84"
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
cutover_time
integer
The maximum amount of time (in seconds) that the source can be quiesced before a destination file must be made available for read-write traffic.
files_to_copy
array[files_to_copy]
A list of source files along with the destinations they are copied to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory.
hold_quiescence
boolean
Specifies whether the source file should be held quiescent for the duration of the copy operation.
max_throughput
integer
The maximum amount of data (in bytes) that can be transferred per second in support of this operation.
integer
The maximum amount of time (in seconds) that the source reference file can be quiesced before the corresponding destination file must be made available for read-write traffic.
reference_file
reference_file
Example request
  "cutover_time": 10,
  "files_to_copy": [
      "destination": {
        "path": "string",
        "svm": {
          "name": "svm1",
        "volume": {
          "name": "volume1",
      "source": {
        "path": "string",
        "svm": {
          "name": "svm1",
        "volume": {
          "name": "volume1",
  "reference_cutover_time": 10,
  "reference_file": {
    "path": "string",
    "volume": {
      "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
7012352
File locations are inconsistent. All files must be on the same volume.
7012353
Exceeded the file operations supported number of files.
7012354
Unable to pair the number of source files to destination files.
7012357
Cannot start a file operation until all cluster nodes support the file operations capability.
7012358
The specified source path is invalid.
7012359
The specified destination path is invalid.
7012360
The SVMs are not in an intracluster peering relationship.
7012361
The SVMs peering relationship does not include application "file-copy".
7012362
The SVMs are not yet in a peered state yet.
7012363
Cannot copy files. All file operations must be managed by the destination SVM's administrator.
7012365
Copying a file between clusters is not supported.
7012367
A reference path may only be specified if multiple source paths are specified.
7012368
The reference path must have a matching source path.
7012371
The reference cutover time exceeds the maximum allowable time.
7012374
Source volume and destination volume have different home clusters.
7012376
Operation not allowed on a volume that is part of a SnapMirror Synchronous relationship.
7012377
Cannot start a file copy operation on the volume because an active volume conversion is in progress.
13107223
Operation not supported for FlexGroup volumes or FlexGroup constituents.
196608143
Cannot start operation. The volume is undergoing a secure purge operation.
string
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
file_reference
path
string
Path of the file or directory.
svm
svm
volume
volume
files_to_copy
destination
file_reference
source
file_reference
reference_file
path
string
The source reference file. If a reference file is specified, data for other files being copied will be transferred as a difference from the reference file. This can save bandwidth and destination storage if the specified source files share blocks. If provided, this input must match one of the source file paths. This input need not be provided if only one source file is specified.
volume
volume
file_copy
File copy
cutover_time
integer
files_to_copy
hold_quiescence
boolean
max_throughput
integer
integer
reference_file
reference_file
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
