Start a file copy operation
Initiates a file copy operation on flexible volumes, specifying the files and their destination paths. Use this endpoint to automate file transfers within your storage environment.
HTTP method and endpoint
POST /storage/file/copy
Introduced in
ONTAP 9.8
Usage notes
Starts a file copy operation. Only supported on flexible volumes.
Required properties
files_to_copy- List of files with the destination they are to be copied to.
Default property values
cutover_time- 10 -
hold_quiescence- false -
max_throughput- 0 -
reference_cutover_time- 10
Related ONTAP commands
volume file copy start
Copying two files
The POST request is used to copy file(s).
# The API:
/api/storage/file/copy
# The call:
curl -X POST "https://<mgmt-ip>/api/storage/file/copy" -H "accept: application/hal+json" -d '{"files_to_copy":[{"source":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/src_f1"},"destination":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/dst_f1"}}, {"source":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/src_f2"},"destination":{"volume":{"name":"vol_a"},"svm":{"name":"vs0"},"path":"d1/dst_f2"}}]}'
# The response:
"job": {
"uuid": "b89bc5dd-94a3-11e8-a7a3-0050568edf84",
"href": "/api/cluster/jobs/b89bc5dd-94a3-11e8-a7a3-0050568edf84"
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
cutover_time |
integer |
The maximum amount of time (in seconds) that the source can be quiesced before a destination file must be made available for read-write traffic. |
files_to_copy |
array[files_to_copy] |
A list of source files along with the destinations they are copied to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. |
hold_quiescence |
boolean |
Specifies whether the source file should be held quiescent for the duration of the copy operation. |
max_throughput |
integer |
The maximum amount of data (in bytes) that can be transferred per second in support of this operation. |
reference_cutover_time |
integer |
The maximum amount of time (in seconds) that the source reference file can be quiesced before the corresponding destination file must be made available for read-write traffic. |
reference_file |
Example request
"cutover_time": 10,
"files_to_copy": [
"destination": {
"path": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"source": {
"path": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"reference_cutover_time": 10,
"reference_file": {
"path": "string",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
7012352 |
File locations are inconsistent. All files must be on the same volume. |
7012353 |
Exceeded the file operations supported number of files. |
7012354 |
Unable to pair the number of source files to destination files. |
7012357 |
Cannot start a file operation until all cluster nodes support the file operations capability. |
7012358 |
The specified source path is invalid. |
7012359 |
The specified destination path is invalid. |
7012360 |
The SVMs are not in an intracluster peering relationship. |
7012361 |
The SVMs peering relationship does not include application "file-copy". |
7012362 |
The SVMs are not yet in a peered state yet. |
7012363 |
Cannot copy files. All file operations must be managed by the destination SVM's administrator. |
7012365 |
Copying a file between clusters is not supported. |
7012367 |
A reference path may only be specified if multiple source paths are specified. |
7012368 |
The reference path must have a matching source path. |
7012371 |
The reference cutover time exceeds the maximum allowable time. |
7012374 |
Source volume and destination volume have different home clusters. |
7012376 |
Operation not allowed on a volume that is part of a SnapMirror Synchronous relationship. |
7012377 |
Cannot start a file copy operation on the volume because an active volume conversion is in progress. |
7018877 |
Maximum combined total (50) of file and LUN copy and move operations reached. When one or more of the operations has completed, try the command again. |
13107223 |
Operation not supported for FlexGroup volumes or FlexGroup constituents. |
196608143 |
Cannot start operation. The volume is undergoing a secure purge operation. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
file_reference
path |
string |
Path of the file or directory. |
svm |
volume |
files_to_copy
destination |
source |
reference_file
path |
string |
The source reference file. If a reference file is specified, data for other files being copied will be transferred as a difference from the reference file. This can save bandwidth and destination storage if the specified source files share blocks. If provided, this input must match one of the source file paths. This input need not be provided if only one source file is specified. |
volume |
file_copy
File copy
cutover_time |
integer |
files_to_copy |
hold_quiescence |
boolean |
max_throughput |
integer |
integer |
reference_file |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
