REST API reference
ONTAP REST API Protocols nfs services endpoints
Retrieving an NFS configuration
# The API:
GET /api/protocols/nfs/services
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services"
Retrieving the mount permissions for a specified volume for a given IP address.
# The API:
# The call:
curl -X GET curl -X GET "https://<mgmt-ip>/api/protocols/nfs/services?protocol_access_rules.volume=testvol12&protocol_access_rules.client_ip=1.2.3.4&protocol_access_rules.auth_type=sys&svm.uuid=525928e9-9f84-11eb-a89f-005056bb70a8&fields=*&return_timeout=15&return_records=true"
Returns the protocol_access_rules structure and provides access permissions for each protocol.
"protocol_access_rules": {
  "nfs3_access_type": "read_write",
  "nfs4_access_type": "read",
  "cifs_access_type": "read_write"
Creating an NFS configuration for an SVM
# The API:
POST /api/protocols/nfs/services
# The call:
curl  -d "@test_nfs_post.txt" -X POST "https://<mgmt-ip>/api/protocols/nfs/services"
test_nfs_post.txt(body):
"svm": {
"protocol": {
  "v4_id_domain": "nfs-nsr-w01.rtp.netapp.com"
"vstorage_enabled": "true"
Updating an NFS configuration for an SVM
# The API:
PATCH /api/protocols/nfs/services/{svm.uuid}
# The call:
curl -d "@test_nfs_patch.txt" -X PATCH "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
test_nfs_patch.txt(body):
"protocol": {
"vstorage_enabled": "false"
Deleting an NFS configuration for an SVM
# The API:
DELETE /api/protocols/nfs/services/{svm.uuid}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/nfs/services/4a415601-548c-11e8-a21d-0050568bcbc9"
Performance monitoring
Performance of the SVM can be monitored by the metric.* and statistics.* properties. These show the performance of the SVM in terms of IOPS, latency and throughput. The metric.* properties denote an average whereas statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
